Antec truepower II 430 Cap. Question
  • 22turbo
    • May 2007
    • 20
    I have an Antec Truepower II 430 power supply that was supplying an extremely low +5VSB, the only symptoms that it showed was that it would not wake up from standby mode, and it made an annoying high pitched whine. I took it apart and every cap was a Fuhjyyu except the two main Rubycons. All of the small ones in the center of the supply were leaking (47uF,470uF and 1000 uF). I want to replace all of the caps in the supply except the two Rubycons with nichicons (PW series) that I can find fairly easily from Mouser. Do these seem like a good fit?
    10V 1000uF 8x20 --x1
    25V 470uF 8x20 --x1
    50V 10uF 5x11 --x1
    35V 47uF 6.3X11 --x1
    10V 4700uF 16x25 --x4
    16V 3300uF 12.5x35.5 --x2
    Also do you think the recap will solve the whine? Thanks in advance for your help.
    Dan
  • 22turbo
    • May 2007
    • 20
    Re: Antec truepower II 430 Cap. Question
    Also, for the "10V 4700uF 16x25 --x4," would it be okay to use a vr series cap there, those seem to be the only ones that are the correct size.
    Dan
    • PeteS in CA
      • Aug 2005
      • 3578
      • USA, Unsure of Planet
      Chances are that the whine is either the main loop is oscillating, due to failure of an O/P cap, or the +5V Stby regulator switching at the wrong, audible, frequency due to the failure of one of those small caps (which might also be the reason the +5V Stby is low). So yes, recapping with good caps is likely to fix both problems. However, do not use those VR series caps in recapping the P/S. IIRC, the VR series is a high quality general purpose series, not suitable for use as output caps. Only use low impedance caps for P/S output caps - e.g. Nichicon PM, PW or HE series, United Chemicon LXY, LXZ, KY or KZE or series, or Rubycon ZL series.
      PeteS in CA
      • 22turbo
        • May 2007
        • 20
        Sorry if this is a newbie question, but what does o/p stand for.
        Dan
        • 22turbo
          • May 2007
          • 20
          Which brands do you guys prefer between these, United Chemicon KY or Nichicon PW/HE?
          Dan
          • 22turbo
            • May 2007
            • 20
            Well, it doesn't look like I'm going to be recapping this PS. While I was taking it apart I realized that a section of the circuit board in the center near the transformer was all scorched. I can't believe the power supply was still moderately operational when I took it out! I'll post some pics of the carnage soon.
            Dan
            • PeteS in CA
              • Aug 2005
              • 3578
              FWIW, PW, LXZ and FC are approximate equivalents - C-V-case, Z and rated life. HE and KY are approximate equivalents - C-V-case, Z and rated life. As I've mentioned elsewhere, water-based electrolye caps make me nervous; HE and KY are of that type, though with relatively low water content compared to other aqueous series. So I would have a slight preference for PW, LXZ and FC; at least some P/S mfrs use HE, KY and ZL (lower Z, higher rated current, shorter rated life than HE or KY), so I may be a little too conservative.
              PeteS in CA
              • gonzo0815
                • Feb 2006
                • 1600
                It is not very uncommon in PSU`s, that some parts are visible scorched or darker due to wrong compponen placement or to less saefty marging.
                But some pic`s would be a good idear.
                • 22turbo
                  • May 2007
                  • 20
                  I agree, but this supply actually got hot enough to melt the solder around a diode, which seems a little excessive to me. I'll probably be buying a seasonic to replace it.
                  Dan
                  • 22turbo
                    • May 2007
                    • 20
                    Heres some pictures of the power supply. In the picture of the burnt circuit board, it's kind of hard to see, but the solder is melted around that top right pad in the burnt area so that there is no connection to the diode it's connected to.
                    Dan
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      If your unsure, toss it. From my point of view, may be the root cause was an cold solder joint and re soldering with some amount of solder and may be aa copper wire as reinforcement for the pcb it should be ok.
                      May be the diode is now degraded from the heat, so replacement would be good.
                      • rabbituk
                        Antec TruePower 380p failed after intermittent supply, suspect MOV
                        by rabbituk
                        I have an Antec TruePower 380p PSU that I had repurposed from a Sonata case. It had been working fine on a server in the loft using the Wake-on-LAN feature regularly until a couple of recent power outages where the power became very unstable - going on/off very quickly. There is now no output whatsoever from the PSU & fan isn't working. There was a pop when I attempted to turn it on.
                        Upon examination, it appears that voltage isn't getting very far so I believe the immediate issue is within the first stage. There is a green component that I am not familiar...
                        12-01-2020, 03:26 AM
                      • Gjackson
                        ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
                        by Gjackson
                        Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
                        01-13-2024, 10:34 AM
                      • 90Ninety
                        Coil Whine , buzzing, identifying parts R9 Fury
                        by 90Ninety
                        I have an R9 Furty Nano ( R9 2XX IIRC ) that I want to put to use , I got it on ebay for quite cheap but, it has some of the worse coil whine I have heard .
                        I tried putting a long tube on my ear and hovered it around the card while in use , I cannot pinpoint it . However I my educated guess is , that it the whine is an inductor coil and it is one or all of these in the picture . Does anyone know what part this is and what part I can replace them with .
                        Perhaps likely is that I am missing something else it could be , here is a stock picture...
                        12-15-2022, 04:18 AM
                      • Topcat
                        Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
                        by Topcat
                        Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
                        Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
                        09-29-2024, 03:55 PM
                      • sirpsychol
                        Antec Earthwatts EA-380 smd element type/value
                        by sirpsychol
                        While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                        09-03-2023, 07:58 PM
