Need help with replacement caps for kzg series
  • markusm
    • Apr 2014
    • 43
    I've seen some other posts from other people on here, and some others recommending which series from other manufacturers will work. My problem is I can't find anything that really matches...
    I'm wondering how strict I need to be when trying to match the specs of the new capacitors. I know the voltage rating can be hire (and have had it recommended to me that I use a higher voltage by one person on another forum), and that the capacitance should be the same... But I'm not sure exactly about some of the other things...
    If I understand correctly the ripple value should be as high or higher, but what about impedance? If it does't match should I err on the lower or higher side? And of all the specs, which ones are going to be more or less critical than others?
    If it helps the caps I am replacing are 470uf 16v kzgs, and they are in an infocus projector. Also, is there any problem with using caps that are 2mm larger in diameter? Here is a picture: The caps in question are on the right...
  • mariushm
    • May 2011
    • 3799
    Re: Need help with replacement caps for kzg series
    In general, impedance should be as close as possible or LOWER. Ripple value can be higher.
    Even though the specs are not as good as the ones of the KZG, I would recommend going for Panasonic FM or FR , 470uF 25v. (there's room on the board, so go with 25v if you find them)
    As it's a projector, the capacitors will run in a hot environment and those capacitors have a high lifetime and they should be "close enough".
    • markusm
      • Apr 2014
      • 43
      Great thanks for the tip. I was leaning towards a 25v already. Partly due to a previous person telling me I ought to, and partly because some of the other series caps would have some specs right on, but the ripple was a lot lower. I looked those FMs up and they look to be the closest of any other series I've looked into.
      One question... would it be better to go with the one of same diameter, but longer if clearance is okay? The one that's 2mm wider has slightly lower impedance and higher ripple. I'm not sure if the 1.5mm difference in lead spacing would have any ill effect?
      Thanks again!
        master hoarder
        • May 2008
        • 12164
        If you have the clearance for the higher capacitor, then it doesn't really matter. The wider capacitor will just have to sit a few mm off the board since the lead spacing would be larger, thus not allowing the cap to go all the way down to the board (if you do go that route, don't force the cap to go all the way down to the board).
        I doubt the slightly lower ESR and better ripple specs of the wider cap will make much of a difference (if any) in terms of longevity and performance.
        • markusm
          • Apr 2014
          • 43
          Thanks for the reply. I've also been asking on audiokarma's DIY forum and it was suggested that I should go with one with the same lead spacing. Once I had a chance I checked my clearance and there was plenty of room so I ordered the longer ones.
          I got them in today and planned to do the repair, but both my tips seem to be too big for the size of the pads around the holes on the circuit board. I successfully replaced one of the caps, but it was a pain in the rear so I'm going to wait until I order a smaller tip to do the rest.
            master hoarder
            • May 2008
            • 12164
            Do you have pictures of your tip or link to your iron? I use a 5 mm bevel for almost all of my recapping. Haven't found a tip that is "too big" for removing caps so far .
            If anything, bigger tips make the job easier as you have more "heat reserve" (helpful on thick traces) and can usually desolder leads on small caps at the same time so I can just pull the cap straight out vs. having to wiggle it out.
            • markusm
              • Apr 2014
              • 43
              I can try to get pics after work today. I took another stab at it last night and desoldered the rest of the caps. I believe the tip that came with it was an 1/8" flat tip (the kind that's round on one side, flat on the other if I'm forgetting the name of it). Guessing, I'd say the solder pads are about 3mm or so in diameter... It's much smaller than I was expecting.
              I think I can make it work with what I have, and am going to take another stab after work when my son can help me, as I need him to hold it steady to use my solder sucker to clear the holes to add the new caps.
              It also seems like the solder on the original caps is hard to melt. I have my iron set at 750 deg. and it seems like it takes longer than it should for it to melt. Do I have my temp high enough? This is my 1st adjustable iron that has the temp settings shown on it, my butane iron is adjustable, but I always just turned it all the way up... now I'm trying to learn to do things the right way.
                master hoarder
                • May 2008
                • 12164
                Sounds like you have a chisel tip - which is always preferable over the bog-standard conical (pencil-like) tip.
                Yeah, that's probably lead-free solder. I definitely recommend you get some gel or liquid flux and put it on the joints before trying to desolder - it really helps. It also helps to add a blob of solder on the iron's tip.
                I'm guessing you have one of those 936 clone stations with the Hakko clone tips? If so, I just found recently that their temperature probe is located very far from the tip, so when the tip conctacts the board, the tip temperature often drops much below what the LCD displays. For that reason, I usually crank mine to 350C (about 660F) or more. When I am impatient, I just put it on full tilt at 460-480C.
                • markusm
                  • Apr 2014
                  • 43
                  The iron is a weller WES51. I decided to try using my burtane iron to desolder the caps, before I knew I had replies to this, and have ruined the trace around one of the holes. The tip of the iron slipped into the hole while I had the solder sucker on the other side of the board, and I think ripped the trace off when I pulled it out. The rest of them seemed to have turned out fine.
                  So now I'm trying to figure out how to fix that. Its a two sided board so the trace coming from this hole is on the opposite side of the board from the trace that got ruined. I think my only option is to scrape of the plastic coating and solder that lead to the top side of the board... Unless someone has any other advice?
                    master hoarder
                    • May 2008
                    • 12164
                    Means the butane torch tip was way too hot. The only other time it can happen is if the board was heat-damaged before (usually an improper design where a certain component or two may cause darkening on the board).
                    Too cold of a tip can also damage the board. The normal reaction is to start pressing the iron harder on the board in hopes of better heat transfer. But what ends up happening is the tip often slips and scratches other traces or damages the current trace.
                    Yes, that should be fine.
                    • mariushm
                      • May 2011
                      • 3799
                      Either tip too hot, or you pressed too hard on the pad.
                      View this video which should explain some things about how proper soldering is done:
                      https://www.youtube.com/watch?v=vIT4ra6Mo0s
                      https://www.youtube.com/watch?v=AY5M-lGxvzo
                      The video (and the series) seem dated but the information is still valid.
                      • SwedishDiesel
                        Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                        by SwedishDiesel
                        Howdy folks,
                        I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                        10-30-2021, 12:47 AM
                      • rewease
                        Replacement for the Siemens Bakelite caps in an early 1980s SMPS
                        by rewease
                        There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
                        Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
                        Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
                        09-17-2023, 12:53 AM
                      • crosswinds
                        Assistance with identifying replacement caps on ASUS P5VDZ-MX
                        by crosswinds
                        So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
                        Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
                        Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
                        Its a ASUS P5VDZ-MX board.
                        I would really appreciate some assistance on what the best replacement caps would be for these:
                        Panasonic(M)...
                        04-17-2024, 04:25 PM
                      • SluggerB
                        Can't find exact matching caps for replacements, what should I get to prevent video issues?
                        by SluggerB
                        I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
                        I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
                        The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
                        04-05-2024, 07:47 PM
                      • TomGJ
                        Genelec 8020C Bad capacitor
                        by TomGJ
                        Hi All, So I have two Genelec 8020Cs that are about 10 years old, one of them stopped switching on. I took it apart, fuse was blown, and I've traced the short to one of the two large capacitors on the circuit board.
                        Now from looking at the Capacitors, they seem to be from Samwha's SD Series with the following specs: 3300uf, 35v, 85C, 25 x 16 mm Radial.
                        The problem is, I can't find any capacitor from Samwha's SD Datasheet that matches these specs. The closest is 3300uf, 35v, 85c but 31.5 x 16mm, with a max ripple current of 2.5A. I'm guessing the 25mm is custom made for...
                        11-02-2024, 07:45 AM
