Just a few questions without getting into much info. My computer keeps restarting itself when it loads normally (Windows ME). But in F1 bios setup utility, it stays running (approx 45 minutes) without a restart. CPU and System temps in bios setup are 35-45C. Shutdown temp is 75C. I pulled the case off an noticed a few buldging caps. I booted normal with a floor fan blowing into the computer, to no avail, kept restarting (improper shutdown). PSU fan had gone out and I replaced it but I still have the restart problem. It could be just me but this happened about the same time that I installed a daylight savings patch for Windows ME from the internet, maybe nothing. Help thanks, SY
Computer keeps restarting?
Re: Computer keeps restarting?
You just answered your own question. Recap it, the reboots will go away. All it takes is one bad cap to cause problems. DST patch had nothing to do with it, coincidence.Originally posted by SybariteI pulled the case off an noticed a few buldging caps.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
by CaimanoMotherboard PU551LA Ver 2 with Intel i5 4210U
I bought the motherboard as faulty to replace a similar one not repairable because it was completely shorted.
3V EC was shorted to ground because of EC chip. IT8585E FXA replaced with IT8585E FXS. Motherboard now works and I am able to recharge the battery, install Windows and update BIOS from Ver 207 to 210 with EZ Flash, but it has the following problem: Every time I power off the laptop with power switch or with Windows shutdown the laptop apparently turns off, but the power LED remains on and it's not possible to restart the laptop.... -
by kingskieHello all,
I got macbook pro A1989 that has sleep wake failure..always restart when put in sleep mode or close the lid..if i shut down and close the lid there would be no problem at all.. already reinstall the mac os but still has the same problem even restore with DFU mode.
and for macbook pro A1707, this one always restart when i try to shut down..always restart when put in sleep mode.
can anyone help me? @piernov, @mon2 ?
thanks before -
by shouriHi guys, can someone help me?
I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
Board model is dm70 la-f401p rev:1.0 2017-09-20.
At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
After a few days test, is seems ok.
Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same.... -
Dear all.
I'm a less knowledgable member who would appreciate some guidence.
I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
When the restart occurs, the screen blacks out leaving a light area alomng the edges fading... -
by kacangpoloI have problem with my laptop, with code board X415EA 2.0,
laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
I did :
1. Flash Bios
2. RTC_RST 3.3V
3. LID_SW 3.3V
4. WLAN_WAKE# 3.3V08-26-2025, 04:42 AM - Loading...
