Colorful Capacitors
  • promy
    • Mar 2014
    • 4
    • Bangladesh
    Colorful Capacitors
    Why does capacitors come in so many colors? Specially these bright and bold colors. Does it mean anything? like Tolerance.
    How may i find the tolerance of the capacitor? Without datasheet.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5095
    • New Zealand
    Re: Colorful Capacitors
    On aluminium electrolytic capacitors the tolerance is usually printed directly on the sleeve\can or marked by a letter code, not a colour, and the letter is almost always the letter 'M' in brackets, eg: (M). The "M" tolerance code means +/-20% and that is what most aluminium electrolytic capacitors use.
    This is different of course to the series code which is usually either a 2 or 3-letter code eg: ZLH, KME, RLS, HD, HE, GF etc, although some Chinese manufacturers also use an apparently standardized (yeah, right!) code that reads like CDxxx such as CD203, or sometimes with a letter at the end as well like CD203H. Again, looking up the datasheets is the best way to find information like series type, ESR etc.
    The sleeve colours usually only have significance to indicate series, and this is manufacturer-specific, so unless you have the datasheets it is rather useless information.
    I believe it is only the really old plastic film capacitors which have a colour coded tolerance (actually the whole value is colour coded with stripes like a resistor)
    -David VanHorn
    • PeteS in CA
      • Aug 2005
      • 3583
      • USA, Unsure of Planet
      I've seen both cylindrical and the dipped box-style package film caps with color coding. I've also seen box case axial leaded mica capacitors that used color coded dots for the value.
      With lytics, it'sort of mixed. Different manufacturers have corporate colors, and sometimes use certain colors for certain types of series. I noticed an orange Sprague capacitor. Orange was a corporate color for Sprague, and I've seen that color used on Sprague film ("Orange Drop"), ceramic disc, solid tantalum, and some electrolytics.
      PeteS in CA
      • FluxCap123
        Dell U2312HM Why are these capacitors different colors?
        by FluxCap123
        I have a Dell U2312HM monitor with a bad power regulator. As part of the repair I was going to replace the capacitors near the regulator. All 4 capacitors are the same size/voltage but two are brown and two are black (see attached photos). The reference numbers on the two different capacitors are: 1301(M) and 1321(M). Does anyone know what they mean? Can I use the same replacement capacitors for all four?
        Any advice would be appreciated. Thanks....
        12-06-2021, 08:48 AM
      • dragon3x
        After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
        by dragon3x
        Hi, I have some 32 bits computer motherboards that need repair, as they fail to
        power on.
        Here are some examples :
        (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
        switching supply area).
        (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
        than 6.3 V.)
        1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
        I replaced capacitors with aluminum-polymer.
        3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
        03-21-2025, 02:46 PM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
        by sam_sam_sam
        After all of...
        07-13-2024, 08:14 PM
      • Cama
        Solar Inverter - SMH-II - 2 missing capacitors
        by Cama
        I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
        My model is : EASUN SMH-II 7 KW
        Mother Board : P/N 18947-002401250250
        Maybe the EASUN SMH-II 4.2 KW have the same capacitors
        Thank you...
        09-12-2025, 02:50 AM
