Ceramic Capacitor
  • promy
    • Mar 2014
    • Bangladesh
    Ceramic Capacitor
    Does ceramic capacitors has any polarity? Why other caps have polarity?
    Can i replace a 472 1kv ceramic cap with a 472 2kv ceramic cap in a ATX PSU?
  • paulstef
    • Dec 2013
    • 724
    Re: Ceramic Capacitor
    No, they don't have a polarity. Yes you can replace a 472 1kV with a 472 2kV.
    • PeteS in CA
      • Aug 2005
      • 3586
      • USA, Unsure of Planet
      Polarity has to do with the chemistry of caps that are polarized. One caveat on that replcement. If the part is on the input side of the power supply and one lead of the part connects to chassis, that requires a special safety agency approved part. It's called a Y capacitor, and it is rated for AC voltage.
      PeteS in CA
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
      • chth96
        by chth96
        03-09-2024, 10:03 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        Should I replace polymer capacitor?
        by chth96
        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
        Is this ESR value of polymer capacitor correct?...
        11-18-2022, 04:22 AM
