School computers seem questionable
  • pentium
    • Mar 2006
    • 2778
    At our school, the computers in both the library and one of the computer labs have been really unstable for a while.
    They are all PIII Seanix TCO towers and all of them were bought around the same time. When I see the ones in the library odds are that at least one has hung and must be reset. Every so often I hear the "clank" of the hard drive parking and then spinning back up for no reason and sometimes with the clank the monitor flips out but immediately comes back. In the computer lab, the lab where graphics are most commonly done there have been times when you get video corruption and it gets worse and worse until the system must be reset.
    Now I have no way to open these system or inquire on the conditions of the boards but from what I am observing this sounds like a bad PSU, right?
    The problems also started on all the systems at around the same time (last year) and there has been no changes to the circuits these systems run on for years (1993 when the academic wing was expanded).
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • CaysE
    • Feb 2006
    • 40
    Re: School computers seem questionable
    Volunteer to inspect them... I'm sure they wouldn't mind. Just be aware of the dangers inherent in opening a PSU casing.
    • Tom41
      • Oct 2005
      • 336
      • England
      The school computer technician might not even know about the 'bad caps' phenomena, so tell them about it and point them to badcaps.net for information.
      I'm sure the technician would be happy to open up the PCs themselves and see if there are any bad caps on the motherboard, possibly the PSU as well (provided the mains lead is removed). You could volunteer to probe one of them with an oscilloscope and see if there is severe ripple, I guess.
      Knowing a school though, the staff there are probably less computer-literate than many of the students! At my school, they were so concerned about viruses and inappropriate material that they actually opened up all the machines, disconnected the floppy drive cables and then padlocked them shut again!
      You know there's something wrong when you open your PC and it has vented Rubycons...
      • pentium
        • Mar 2006
        • 2778
        Every computer (and I mean every) in our school has deepfreeze installed and the bios is locked.
        I asked to have one opened and I was given a firm no.
        Find Nedry!
        • Logistics
          • Apr 2007
          • 721
          Just put in a request to your schools administration asking if you can have the systems when they decide to replace them because they "went bad."
          Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
          • pentium
            • Mar 2006
            • 2778
            I'll have to ask roxie.
            Yes, I do know the district's head computer tech on a first name basis.
            Find Nedry!
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
            • kokodin
              windows 10 embeded key on a desktop motherboard - inventory issue
              by kokodin
              Hello, a bit silly question here.
              I work at a school. we have IT class for computer assembling in a technical highschool and we kind of need more hardware for practicing.
              Computers we bought in 2019 had unsuficient motherboards for our regular clases so they were replaced before going online with computers for the first time and licences transfered to new motherboards. they are "windows pro for school" so as a school we are allowed to do that, we just can't have 2 computers with the same licence. So i have a stockpile of unused motherboards. Now that cpu's for them are a...
              02-06-2025, 02:35 AM
              MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
              The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
              Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
              10-23-2024, 03:23 AM
              Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
              The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
              The bq24745 features dynamic power management...
              10-23-2024, 02:50 AM
              RT8015B RT8015BGQW RT8015BGSP Datasheet
              The RT8015B RT8015BGQW RT8015BGSP are high efficiency synchronous, step down DC/DC converter. Its input voltage range is from 2.6V to 5.5V and provides an adjustable regulated output voltage from 0.8V to 5V while delivering up to 3A of output current.
              The internal synchronous low on resistance power switches increase efficiency and eliminate the need for an external Schottky diode. The switching frequency is set by an external resistor. The 100% duty cycle provides low dropout operation extending battery life in portable systems. Current mode operation with external compensation allows...
              10-07-2024, 05:38 AM
