My capacitors aren't bulging
  • mrpmorris
    • Mar 2014
    Hi all
    I have the same problem as this guy (my power blinks 6 or 7 times)
    https://www.youtube.com/watch?v=EbGiXqBAvvo
    I have opened the TV but I can see no bulges in any of the capacitors. Any suggestions?
    Thanks!
  • ukee
    • Jan 2014
    Re: My capacitors aren't bulging
    Had a few of these some thing to Try is unplugging it and push the power button for like 20 seconds then leave it unplugged for like 2 or 3 days and plug it in and try it. worth a try I had 2 sent to me for repair first one sat on the floor unplugged for 4 days till the weekend and it just worked after being unplugged for 4 days second one I did this and that worked on it. good luck.
    • paulstef
      • Dec 2013
      • 724
      Even if they are not bulging, they can still have lost capacitance. To be sure you would need to measure them or just replace them.
      • mariushm
        • May 2011
        • 3799
        Sometimes the fault is not capacitors, but a loose wire at the end of the fluorescent tubes in the panel, or a lamp itself faulty (they can degrade or die of old age).
        You can check if the lamps are faulty or wires loose only by opening the panel. But be careful, those lamps run at high voltage (700-1500 volts).
        Alternatively, you can buy some fluorescent lightbulbs, open them up and connect the wires from those tubes of the bulbs to the connector where the panel lamps are connected. If the panel will run and bulb lights up, you know it's that pair of lamps faulty in some way.
        But this is a bit of a "for professionals" method, it's a bit dangerous to use if you never did it before.
        • twbranch
          Mad Nerd
          • Oct 2012
          • 153
          That is just a temporary fix. I would investigate further to find the problem. That is just a symptom of something wrong!
          • ukee
            • Jan 2014
            Not saying its a fix. Just I live in a small town and we have a lot of power outages and every time we have a power outage I get the same 7 TVs dropped off at the TV store. I do what I said and they work perfectly till the next power outage be it 2 weeks or 5 months. I think it has something to do with the bad power when it comes back on? or from the power board losing power completely? Maybe the boards cool down and that is why they start up when I let them sit? and only one has to be left unplugged for 3 or 4 days for most of them I come back on my coffee break 2 hours later and they start up. I just told him this as it might work for him to just get it going. As I learn more I will probably end up taking them apart and repairing them as for now I am sticking with my dumpster diving stuff its free LOL.
            • paulstef
              • Dec 2013
              • 724
              I guess we need more power outages here.
              • Hitto
                Slightly Bulging Capacitors
                by Hitto
                Would you consider a slightly bulging capacitor defective if it measures perfectly and it is brand-new? To be honest, they are all equally like this: vent is not totally flat but they have very low E.S.R. and VLOSS is negligible.
                So, everything seems perfect apart from the vent looking a bit "strange". They are genuine capacitors, BTW.
                The bad thing is that they are 400V capacitors so testing them just to check how much they last would mean using them on the primary of a power supply, which means the risk of damaging the whole circuit.
                What do you...
                12-23-2024, 05:08 PM
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
              • slybunda
                AA and AAA battery charger capacitors?
                by slybunda
                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                it has inside:
                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                2 x 470uf 16v LZ105c branded as G.Luxon
                not heard of these brands are they any good?
                iv attached photos of the charger and the board inside for an idea on the type of...
                12-24-2023, 04:41 AM
                After all of...
                07-13-2024, 08:14 PM
              • Cama
                Solar Inverter - SMH-II - 2 missing capacitors
                by Cama
                I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                My model is : EASUN SMH-II 7 KW
                Mother Board : P/N 18947-002401250250
                Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                Thank you...
                09-12-2025, 02:50 AM
