SMD capacitor replacement
  • Sofian75
    • Aug 2023
    • 87
    • France
    When you don't have a schematic and you want to replace a burned capacitor (on a laptop), other than matching the size, should you go for the highest capacitance possible or the lowest?
    Could a different capacitance than the original be worse than not replacing it at all?
    • 31283
    you should look at what it connects to and then look at similar schematics for ideas
    • Sofian75
      • Aug 2023
      • 87
      • France
      • aurgathor
        • May 2012
        • 16
        In a laptop a good portion of the caps will be filtering capacitors, so there should be very little in pF range. Since mobos often have duplicate caps on the same voltage rail, you can get a pretty good approximation about its capacity range by looking at the others.
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • artvandalai
          Where can I get compatible capacitor for replacement?
          by artvandalai
          Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
          12-28-2024, 10:15 AM
        • r2digital
          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
          by r2digital
          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
          04-18-2024, 03:50 PM
        • rwkish
          Discontinued Capacitor looking for Replacement
          by rwkish
          Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
          08-18-2024, 06:54 PM
        • Hylax
          Replacement capacitor options please?
          by Hylax
          Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
          08-09-2024, 11:25 PM
