supacon!!!
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    supacon!!!
    These are new to me. Caps are colored like Rubycons, and have the same stylised writing... A very ironic and fitting name
    Ludicrous gibs!
  • pvone
    • Oct 2006
    • 11
    Re: supacon!!!
    i've seen some of those before, quite a while ago. can't remember who made the board they were on... never seen any since. (good thing i guess!)
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Re: supacon!!!
      After having actually done a search, I see that they're common on the Gigabyte board I have in my posession .
      Ludicrous gibs!
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Re: supacon!!!
        I wonder if the name is inspired by gangsta rap: " Supa Con!" Isaac Hayes could intone that perfectly!
        PeteS in CA
        • starfury1
          • May 2006
          • 1256
          Re: supacon!!!
          Supa Con!
          I like that
          maybe they are GSC in disguise Ergo..... Supa Con!
          • PNI E.
            Tv grundig 50vlx21ldl horizontal colored limes
            by PNI E.
            Good morning guys, I have this tv that have horizontal colored lines ( green, blue, black). I tried to disconnect the two ribbon cable on the t con, first the left side and then the right side. But the lines still are there…so I tried the tape method but didn’t work. Can someone help me to try to fix this tv. I give you the photo of the panel, and the panel with the left ribbon unplugged and then the right. Thanks for your help...
            06-11-2025, 09:45 AM
          • rapid911
            Vizio M58Q7 colored horizontal lines
            by rapid911
            Hi guys, I have a Vizio M58Q7-J01 and now there are some colored horizontal lines on the screen. Could someone tell me if it's probably a panel issue or something related to other parts and can be fixed? Thank you in advance....
            05-28-2023, 04:17 PM
          • Maverick1234
            Colored Vertical lines on Samsung UN55C6400RF TV
            by Maverick1234
            I have a Samsung 55inch TV (UN55C6400RF). It has started showing colored vertical lines. I have opened the TV and the power board had one pin (out1-) which is discolored (Model # bn44-00358b). Can this be bad or is it the T-Con board (Model # D03464E0J09B6012066). Any recommendations on diagnosing the issue?
            Thanks,
            Sanjay
            09-13-2021, 02:43 PM
          • morinb
            Samsung UN55KS8500 - previously power-cycling, now vertical colored bars
            by morinb
            Edit: this is for a UN55KS8500FXZA
            I came across this thread last week where another user had a fix for my original problem of a power-cycling TV. I identified and removed some burnt-out resistors, after which the TV no longer power cycles, but now displays vertical colored lines down parts of the screen. There's also a green-colored "cloud" near the bottom-right when using the replacement mainboard.
            I see these lines whether I'm using my original mainboard or the refurb I got from an online parts store, just in differing amounts/screen-space....
            07-23-2020, 12:45 PM
          • qwerki
            Advice for replacements for some Rubycons in a Dell Precision 670
            by qwerki
            Hello, I was hoping some of you kind souls could give me some advice.
            I have a couple of old motherboards I'd like to have a go at repairing. They come from Dell Precision 670s, and the caps have gone bad.
            Ultimately, I intend on getting rid of them, but it's a fun project to practise my (de)soldering on, so I want to see if I can resurrect them, even if only temporarily. I'd also like to check if there's anything on the onboard RAID array I missed backing up (I don't think there is, but you never know).
            It's the VRM caps that visibly leaked, so I removed...
            06-20-2021, 07:20 AM
