Trying to understand how to find best replacement cap for old parts.
This topic has been answered.
  • samoelec
    samoelec
    • Apr 2024
    • 3
    • Taiwan
    Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
    Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
    The power supply board is exactly the same from this post so I'll just steal it for now.
    I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly realized the datasheets for these Lelon caps are probably long gone or the information are not complete.
    For example, it uses a huge 68uF 450V capacitor as output filter, but in the datasheet I found on Mouser, they didn't even list 68uF so it seems they no longer produce 68uF caps.
    For now, I can only deduce from the nominal characteristics from the data of 82uF 450V LSG cap:
    that a 68uF one will have ripple current less than 0.45 and ESR higher than 2.427 ohm.
    One of the 68uF 450V cap I can find in my local electronics parts store is a Hitachi HU3 cap, which I also found the datasheet. (p.177 in PDF reader or P.33 on the page footer.)
    This cap have ripple current higher and ESR much lower (1.3 ohm, almost half) than the Lelon cap, which makes me start to wonder: How to judge a replacement cap is "good enough" or "close enough" to the ones that are no longer in production? As finding a exact replacement can prove to be very difficult
    After some Googling, I understand that higher ripple current is generally a good thing, but whether lower ESR is good or bad depends on the circuit design.
    My question is, what does it depend on and how do I see it on the circuit?
    Take this 68uF 450V capacitor as example, I can see that it is used to filter the output of the bridge rectifier, so higher ripple current is good. But I can't determine if using a capacitor with half of the original ESR is good in this scenario.
    Also, it's more difficult for a newbie like me to identify what all other electrolytic capacitors are meant for in the case of this power supply board.
    I know I should probably Google more myself, but sadly I don't even know what keywords are suitable for what I'm trying to learn.
    Any suggestions and knowledge sharing are welcomed!
    P.S.
    I can provide much more clearer and hi-res pictures of the board if necessary.
  • Answer selected by samoelec at 04-09-2024, 11:28 AM.
    momaka
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    By the looks of it, that 450V 68 uF capacitor is filtering just rectified mains power. So in that case, ESR ratings are pretty much irrelevant.
    While I generally support and encourage people to do full recaps when dealing with a power supply, I sometimes do make an exception for the mains filter cap. In particular, if the power supply does not have Active PFC (APFC) circuit, the mains filter cap is not under that much stress. As such, even 2nd/lower-tier brands like Lelon, Teapo, OST, and etc. can still last for many many years without causing any issues. Of course if cost is not an issue (and since this is for an oscilloscope - a rather useful piece of test equipment), then go ahead and replace the mains filter cap.
    In regards to your question about ESR and how far lower or higher you can go - that pretty much applies to the output of switch mode power supplies only. In general about 50% +/- deviation usually will almost never cause any issues, and some PSUs can tolerate even further deviation. +/-100% is not uncommon, and a few can work with even 2-3x lower or higher ESR.
    Typically, the types of power supplies that are more likely to have an issue with large ESR deviations are the ones that use a continuous design (i.e. typically the presence of a large output toroid on the secondary side before the output capacitors.) On the other hand, discontinuous (flyback) designs are very very tolerant of ESR deviations. If you go way too low on the ESR with these, sometimes you might get a high-pitched whine from the PSU at low loads. But it's nothing dangerous for the PSU. I have recapped the 5VSBs circuit of many ATX PSUs with ultra-low motherboard-grade caps, and it's never been an issue.
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      68uf mouser ...
      https://www.mouser.co.uk/c/?q=450v%2068uf
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        • mkdj
          MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
          by mkdj
          About me, my goal and the equipment I (don't) have:
          I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
          About my issue and my goal:
          A friend of mine has a MacBook Air M1 A2337 that does not...
          04-03-2025, 08:28 AM
        • shovenose
          Source for quality stumpy 450v/150uF STGCON cap replacement
          by shovenose
          I am attempted to replace this capacitor to repair a power supply. I put in a random used NCC KXG 450v/100uF and it worked but it's too tall and skinny to reinstall the heatsink and even if I drill a big hole in the heatsink for the cap it would still be too tall and the power supply will no longer fit in the network switch.
          The original cap seems to be 35mm in diameter and maybe 25mm in height. I could probably go up to 30mm in height and be OK.
          Thanks for any help with a source for these, I only need one or two, and the cheaper the better. I found some on eBay that...
          08-17-2021, 10:47 AM
        • ezenia
          PS4 controller left stick potentiometer replacement issue
          by ezenia
          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
          09-30-2023, 02:19 PM
        • boosti45
          Macbook pro logic board replacement parts quesion
          by boosti45
          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
          08-21-2024, 05:23 AM
        • r2digital
          klipsch kda-500 amplifier suitable power supply capacitor replacement ?
          by r2digital
          I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
          04-18-2024, 03:50 PM
