Yageo 400V 680uF measuring 580uF
  • jm1234
    • Jan 2024
    • 68
    • Slovakia
    I have a Yageo 400V 680uF that is currently measuring 580uF (Measured by UNI-T UT603). Does that normally qualify for replacement?
    Details: Siemens tumble dryer getting Error 25 after an hour or so, on all last 3 runs.
    I checked the circuit boards quickly and this capacitor sticks out, nothing visible, not even bulging though. It costs 12euro, so I'd like to get your feedback first. The main thing on that board seems to be a motor controller (for the compressor) https://www.mouser.sk/ProductDetail/...xvzUNHBQ%3D%3D.
    Daniel
  • slybunda
    • Feb 2012
    • 139
    Whats the esr like on the cap?
    • jm1234
      • Jan 2024
      • 68
      • Slovakia
      I don't have that kind of equipment, sorry.
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        Electrolytic capacitors, typically, are +/-20%, so on the low end the cap can be as low 544uF.
        PeteS in CA
        • jm1234
          • Jan 2024
          • 68
          • Slovakia
          ok I got me an ESR tester and that cap shows 0.33ohm.
          • jm1234
            • Jan 2024
            • 68
            • Slovakia
            ESR is 0.33ohm, what do you think?
            • slybunda
              • Feb 2012
              • 139
              Check with the datasheet for that cap to see how it stacks up.
              • jm1234
                • Jan 2024
                • 68
                • Slovakia
                Easier said than done, . Mine has a sticker with what looks like a Bosh part number (BSH 9000558676), but I couldn't find any more details on that.
                I'm attaching a photo in case it would help.
                ​I only found one similar on web, not sure it's identical and the data sheet doesn't specify ESR: https://static6.arrow.com/aropdfconv...an_lv_2011.pdf
                Any opinion welcome.
                • petehall347
                  • Jan 2015
                  • 4450
                  • United Kingdom
                  look for . yageo lg series datasheet
                    • 31294
                    http://www.paullinebarger.net/DS/Yag...G%20Series.pdf
                    • jm1234
                      • Jan 2024
                      • 68
                      • Slovakia
                      Thanks guys, that indeed looks like what I have. However, I don't see ESR value in that data sheet.
                      • slybunda
                        • Feb 2012
                        • 139
                        https://il.farnell.com/epcos/b43511a...-in/dp/3437421
                        This one has esr of 0.14
                        • jm1234
                          • Jan 2024
                          • 68
                          • Slovakia
                          I switched the capacitor for a new one but that didn't solve it. Next up is likely the main invertor chip IKCS17F60F2A, but I'm not 100% sure, not even 51%. I guess it could still be the compressor leakage. The chip is 16.3eur on Ali, I guess I will try that. The whole invertor board is 335eur as original Siemens spare part.
                          • Petros_Z
                            candy tumble dryer (evoc 981 at-s) Component 738
                            by Petros_Z
                            Hello. I have a board of a candy tumble dryer (evoc 981 at-s).
                            It does not give an error but it keeps drying even without load. It has 3 ntc. Two are for the clothes and one for the compressor. I measure them and they look ok. I went to the board to measure the voltage given to them. It gives about 4v and it is going down as the ntc value going down.
                            Because I wanted to measure more easily I tried to solder wires on the board. Probably I manage to destroy the component of the title. It looks like as a smd resistor. Hopefully there were other two same components. I disorder them and...
                            01-04-2025, 02:17 AM
                          • slybunda
                            Yageo brand any good?
                            by slybunda
                            another one of these posts lol, got to check though in this day and age, better safe than sorry.
                            Yageo brand of ceramic caps, anyone know if its good or bad?
                            thanks
                            01-02-2024, 03:16 AM
                          • hikomalek
                            SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                            by hikomalek
                            Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                            When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                            Transformer:
                            |Info| Primary | Aux | AB | CD|
                            |Ratio|1|25|40|12|
                            |Voltage AC|230V|9.2V|5.8V|19V|
                            |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                            I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                            09-19-2025, 03:30 AM
                          • Rado108
                            Measuring ESR in-circuit: LCR or ESR meter
                            by Rado108
                            Hello. Which tool is better for in-circuit testing of e-caps? I was thinking about getting proper LCR meter like DER DE5000 but as i have seen more accurate are ESR meters like ESR70 from Peak if we are measuring in-circuit. Is that true?
                            Sometimes ESR can not be accurate when in-circuit but still want to get the best tool for it.
                            09-10-2023, 10:42 AM
                          • notallbad
                            Heat pump tumble dryer regas
                            by notallbad
                            Just wondering if anyone has successfully attempted a re-gas on a heat pump tumble dryer.
                            The dryer currently in question runs on R134a.
                            The dryer has been completely stripped down/cleaned/tested and re-assembled however there is no heating/cooling effect so working on the assumption it requires re-gassing. Of course, its likely theres a leak which would require soldering or even the possibility that the compressor has an internal fault even though it is running.
                            I was thinking of getting a car aircon regas kit or probably easier but slightly dearer an hvac...
                            07-16-2023, 01:27 PM
