If I replace with inferior capacitor, Is it No harm to other IC components at all?
  • chth96
    • Nov 2022
    • 118
    • indonesia
    I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
    Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
    It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
    So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
    I know that these capacitor will not last as long as nichicon capacitor did,
    But I doubt that inferior capacitor really harms nearby IC components, So I dread that Not only It doesn't last long, it may also chip away at lifespan of nearby IC components.
    Click image for larger version  Name:	rik7f4o12gd21.png?width=760&format=png&auto=webp&s=238f01bb43f1cf9e1334ef86c91d383eccdca2e5.png Views:	0 Size:	15.5 KB ID:	3166505
    • 30985
    nobody can say if it could cause damage unless they have a schematic
    • chth96
      • Nov 2022
      • 118
      • indonesia
      below link is a schematic for this pcb.
      https://www.acidmods.com/RDC/SEGA/Dr...OM%20XV779.pdf
        • 30985
        so which cap is it? or is it all 7 100uf caps?
        who made that list btw? you should be fitting tantalum not more crap smd electrolytics.
        • chth96
          • Nov 2022
          • 118
          • indonesia
          I don't know who made this list for the first time.
          It was stumbled on when I browsed through reddit site.
          https://www.reddit.com/r/consolerepa...pacitors_just/
          and a schematic is came from acidmod.com
          https://acidmods.com/forum/index.php?topic=44892.0
          By the way,Can I replace all of cap with tantalum?
          And Is it okay to purchase tantalum capacitor from aliexpress?
            • 30985
            firstly lets talk about cap lists.
            they should contain the board number - because there are different versions,
            the cap uf, volts and ideally esr & ripple and most importantly size (width / height)
            a lot of people forget that bit and people buy caps that either dont fit or are too tall for stuff to be re-assembled.
            so you can replace electrolytics with tantalums,
            the only reason they dont use them from the factory is they cost like 5x the priice.
            apple, sun & sgi always used tantalums though - because it's expensive stuff.
            the bi-polar caps are special, you cant use regular electrolytics or tantalum for those.
            you can use film caps but those are probably too big to fit
            as for ali - i have had no problems with ali tantalums when i was doing xboxes.
            remember to pay atention to sizes so they fit across the pads nicely.
            and i hope you have a fast scope because you may mess up the laser calibration.
            btw, because tantalum dont dry out you can salvage them from old boards
            • chth96
              • Nov 2022
              • 118
              • indonesia
              Thank you very much for your reply.
              I bent all of caps in order to fit the height of space between pcb and plate like below jpg attachment.
              It seems that all of caps narrowly fit to space,And I test its performance by comparing it with another intact laser pickup PCB which I never have soldered at all and works fairly well.
              I inserted some burned CD-R and It seems that It also able to recognize any burned CD-R which can be recognized in the intact laser pick up PCB and It also stuttered to read some CD-R which is stuttered to read in the intact laser pick up.
              It seems that performance of pcb, which I replaced capacitor, is almost the same with intact laser pickup pcb.
              I plan to replace this regular electrolytics,which I soldered, with tantalium caps if it fail to recognize all of CD-R again..
              As for the bi-polar caps in the list,I heard that It is audiograde capacitor, So I think it should not be replaced with common tantalum or film capacitor.
              And I don't know what fast scope is, and not have any osilloscope but I measured resistance of laser diode and It seems that it is still fine
                • 30985
                bi-polar electrolytics are actually rare,
                they used to be used in crt tv's and monitors mostly.
                for audio-path the best caps to use are polypropylene film.
                the downside - if your converting from electrolytic anyway, is they are a lot bigger physically.
                  • Jul 2011
                  • 6037
                  I would recommend that you put wire insulation or heat shrink tubing that is the right size on the the capacitors leads when you put capacitors across traces like that what you have is not a good practice to get into because if when you remount the circuit board and you just happen to move one of those capacitors and the wires lead bends upward you will not know that this has happened and things might not go as planned I have had this happen in the past
                  However putting kapton tape is a good idea to use however you need to put it underneath the the capacitor leads as well but it does not keep the capacitors leads from being pushed together and cause issues that is why using wire insulation is a better solution for mounting capacitors on the bottom of a circuit board if you have enough space to do so
                  One note you need to try to keep the capacitors leads as short as possible to prevent picking up noise interference from the rest of the circuit sometimes this is hard to do sometimes you might need to put heat shrink tubing on the capacitors themselves to keep from shorting out the shell of the capacitor to the circuit leads from the board
                  Good job figuring out what the issue was with CD rom drive one more item that did not end up in the landfill
                  • chth96
                    Is it no harm to replace with capacitor without ripple current rating?
                    by chth96
                    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                    Rubycon YK DataSheet (b...
                    04-19-2024, 05:19 AM
                  • chth96
                    Should I replace polymer capacitor?
                    by chth96
                    a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                    I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                    Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                    Is this ESR value of polymer capacitor correct?...
                    11-18-2022, 04:22 AM
                  • cap__
                    Can I replace 15uf capacitor with 22uf?
                    by cap__
                    "If I wanted to replace an old 15uF/400V capacitor with a new one,
                    I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
                    11-29-2023, 11:16 AM
                  • Prolog
                    RTX 3080 FE Identifying capacitor
                    by Prolog
                    Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                    I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                    I hope these photos make it clear which component I am referring to:
                    (yes, the soldering is a bit botched from removing the blown one, I know)
                    I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                    12-01-2024, 08:27 PM
                  • Sam Scarbo
                    Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
                    by Sam Scarbo
                    My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
                    I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
                    If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
                    See the attached two pictures of the small...
                    09-18-2024, 08:29 AM
