Panasonic cap HC or HB
  • ivtec
    • Dec 2008
    • 1967
    Which of theses caps should i buy?thanks
    http://www.digikey.com/product-searc...22EA&vendor=10
    http://www.newark.com/panasonic/eet-...50v/dp/01M7638
  • selldoor
    Slow Learner
    • 7870
    Re: Panasonic cap HC or HB
    Is this a trick question
    I could ask you what it is for but a better question might be
    when is it for and
    do you need 600 of them?
    • ivtec
      • Dec 2008
      • 1967
      when is it for and
      for H and V supply
      • selldoor
        Slow Learner
        • 7870
        Sorry - you dont follow my odd sense of humour.
        One of the caps you suggest can only be bought in a minimum order of 600
        AND it is out of stock 20 week delivery!!
        I thought you might want the other one
        • ivtec
          • Dec 2008
          • 1967
          Your sense of Humour doesn't make any sense!i don't want to order nothing from those sites i just wanted to know if any of those caps would be good, have a great day.
          • selldoor
            Slow Learner
            • 7870
            OK it was a trick question then
            As far as I can tell either cap would be good providing you have the space.
            One is 30mm Diam the other is 35mm.
            Other main points are ESR which is often thought less important in these large caps and Lifetime 3000 as against 2000.
            I would choose lifetime over ESR in this case but perhaps wait to see if there are other replies.
            To make it easier I attach the comparisons from the same vendor.
            • lexwalker
              • Feb 2011
              • 307
              • Malaysia
              Neither. Usually for those snap ins, my preference would be this...
              http://www.newark.com/panasonic/eet-...u=EETED2E122EA
              Or this one...
              http://uk.farnell.com/panasonic/eete...0uf/dp/1828653
              • ivtec
                • Dec 2008
                • 1967
                Or this one...
                Thanks guys; i have ordered 2 panasonic from Mouser before i saw your posts and they sent me these,but they are a little larger in diameter and shorter in hight see pic, i don't think they fit there,
                i tried to get by sony part #113194011 but could not find any,
                the one that should be by part # 113194011, c6590,c6503
                i have no luck ordering from Mouser first they sent me the wrong fuses now these.
                Thanks and have a Happy New Year
                • lexwalker
                  • Feb 2011
                  • 307
                  • Malaysia
                  Should have told us the diameter of the original capacitors that you wanted to replace. Most of those 1200uF 250VDC snap-ins are 35mm in diameter (like the first capacitor in your first post)...
                    by momaka
                    03-12-2025, 03:42 PM
                  • eryjus
                    by eryjus
                    05-10-2023, 11:21 AM
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                  • black6host
                    Replacement caps for Samson Resolv studio monitor 65A Amp board.
                    by black6host
                    Good day!
                    I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                    I'm going to replace the caps and I'll be the first...
                    02-06-2024, 08:22 PM
                    EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                    by momaka
                    I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                    So, here is the...
                    06-06-2020, 04:39 PM
