Recaping Victor VC921...
  • patriciopat
    MerlinMac
    • May 2007
    • 68
  • patriciopat
    MerlinMac
    • May 2007
    • 68
    Re: Recaping Victor VC921...
    It was very interesting, good capacitors put this victor low cost, giving it a little more stability. You like? regards
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Good job with the soldering! Sheeeeeeesh, those original solder joints were nasty looking! (Dull, brittle lead-free solder that cracks easily and grows "tin whiskers" AKA tin crystals)
      Only other thing I have to say is you used Jamicon capacitors which are of average quality. But they are NOT in a very stressing environment here, so they should be good!
      Muh-soggy-knee
      • lti
        • May 2011
        • 2548
        It kind of looks like the original caps were leaking.
        I wonder what they did at the factory to melt the labels on the caps like that.
        • patriciopat
          MerlinMac
          • May 2007
          • 68
          Truly, it is a shame, but to protest over what is complicated, because no open devices, I just did it for leisure and took the surprise. It cost less than 1 euro change all caps. regards
          • itsthatidiotagain
            • 39
            Sorry to wake up a long dead thread, but I thought it worth pointing out that the design of this multimeter has changed.
            The new design uses a chip on board (aka little black blob), and more surface mount components. It appears to be based on a variant of the Fortune Semiconductor Corporation FS9XXX series multimeter chips, but exactly which one is difficult to tell as not all pins are broken out. There is a high probability that it is one of these guys... http://www.ic-fortune.com/eng/new_product3_3.asp ... exactly which one.. well your guess is as good as mine.
            A full set of teardown pictures here... https://goo.gl/photos/aR3xKELrAAmGa16o7
            The interesting thing is that it has a 24c02 i2c EEROM, presumably for settings and calibration. I'll need to try and find the time to read it and see if it reveals anything useful.
            • itsthatidiotagain
              • 39
              The Victor VC921 "True RMS" is not a bold unsubstantiated claim.
              This variant is based on the HY12P65/HY12P66 the pinout of the little black blob matches this chip *exactly*. (The meter is not as I previously though, based on a Fortune Semiconductor FS9XXX)
              This probably makes the "VC921 True RMS" the cheapest true RMS meter on the market (and also probably the lowest build quality )
              The HY12P65/66 is in fact a True RMS DMM chip. The board layout out is a similar arrangement to the Victor VC890-X series. It *may* even be capable of RS232 output, time to solder on some very small wires and find out.
              Data Sheets, programming info and all things HY12P6X related >> http://www.hycontek.com/e-page2-HY12P.html
              The older versions however are *not* based on this chip, and are not true RMS.
              • TechGeek
                Computer Geek
                • Jan 2015
                • 2254
                To the OP: Could you shrink those images? It's loading down our WiFi. Thanks.
                Permanently Retired Systems:
                Kooky and Kool Systems
                sigpic
                  • 31051
                  lol
                  • TechGeek
                    Computer Geek
                    • Jan 2015
                    • 2254
                    Originally posted by stj
                    lol
                    lol
                    sigpic
