help needed with rosin flux removal!
  • theOracle
    • Nov 2012
    • 163
    I use a rosin flux (Radio Shack p/n 64-022 aka CAIG DeoxIT rosin flux p/n RSF-R80-2)
    It's basically just a tub of pure pine rosin.
    I use a ton of this when soldering, and there is a lot left on the board that needs to be cleaned off. Right now, I use 91% isopropyl alcohol which does a good job, but it seem to lift the outside coating off the circuit board
    what solvent would clean off rosin equally well, and not remove any coating from the board?
    __________________
    the BIG 4
    ~~~ the top tier of low-ESR electrolytic capacitors ~~~
  • Valvados
    • Nov 2013
    • 10
    • US
    Re: help needed with rosin flux removal!
    guess you can bring the alcohol down to 25% with water if you think the water is safe
    I only mention this because I fixed my lcd screen scratch by diluting 50% alcohol to 25%, they say that above 35% can really damage a plastic lcd screen.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      I use 99.995% Isopropyl Alcohol and never had problems damaging any PCB. In fact, the Isopropyl Alcohol I'm using is made by MG Chemicals and it specifically says on it that it is suitable for cleaning PCBs.
      • cheapie
        null
        • Jul 2010
        • 849
        Maybe your alcohol was denatured with acetone - that'll dissolve the coating.
        • theOracle
          • Nov 2012
          • 163
          using standard 91% isopropyl alcohol, like you would buy at Wal-Mart or anywhere in the pharmacy dept. - I doubt they would put any acetone in it, since it is designed to be used on skin etc. - Also there is no acetone smell which I am quite sensitive to.
          __________________
          the BIG 4
          • capkid
            • Oct 2010
            • 1339
            Ditto
            LG Plasma Mal-Discharge Correction Service
            • theOracle
              • Nov 2012
              • 163
              these boards must have a coating on them that is breaking down with most any solvent, even hexane affects them!
              __________________
              the BIG 4
              • EdT
                • Nov 2013
                • 14
                Be sure it is not conformal coating that is lifting off, big difference if it is the actual epoxy on the PCB !
                • theOracle
                  • Nov 2012
                  • 163
                  it is some kind of coating!
                  here is what is crazy, isopropyl alcohol takes off the board coating, but another even stronger solvent tetrachloroethylene (aka non-flammable brake cleaner - aka dry cleaning fluid - aka "PERC") removes the rosin flux and doesn't bother the coating!
                  now I need a non-toxic solvent that will remove the rosin and not the coating!
                  __________________
                  the BIG 4
                  • lexwalker
                    • Feb 2011
                    • 307
                    • Malaysia
                    Sometimes when the coating had absorbed certain chemicals such as those from degraded glue (after removal), it can flake off easily. Either that, or the coating isn't alcohol friendly...
                    Have you tried contact cleaner? Sometimes I've used that instead of isopropyl alcohol.
                    • EdT
                      • Nov 2013
                      • 14
                      You can make sure if there is indeed conformal coating by shining a UV light(black light), the coating will give a whitish color on the PCB.
                      I find it strange that low cost items such as consumer grade motherboards have conformal coatings which is normally for mission critical hardware applications.
                      http://www.dowcorning.com/content/et.../etronicscoat/
                      For tough flux residues I use lacquer thinner it is cheap and available everywhere, but be careful it may melt certain plastic components.
                      Contact cleaner is great, but expensive. Naphtha is another good alternative, but very flammable so is brake cleaning fluid !
                      Yeah I am cheap, after working in the EMS industry for 20+ years you know how to $ave some cash for your own stuff ! ...LoL
                      • acedogblast
                        by acedogblast
                        11-02-2024, 05:13 PM
                      • ChaosLegionnaire
                        how do u use solid rosin flux?
                        by ChaosLegionnaire
                        i recently bought a block of solid rosin flux from aliexpress. i intend to use it for reflowing cold solder joints and cracked solder joints. but im not sure how im supposed to be using it? do i just break off bits and pieces of it with a knife and put the bits of solid rosin on the bad joint im soldering then bring on the iron?
                        i tried asking google and they pointed me to a headphone forum and eevblog? and they said to just dip the soldering iron tip into the solid block. a small piece of flux will be attached to the soldering iron tip end and im supposed to use that to reflow...
                        06-24-2020, 02:34 PM
                      • chth96
                        Is it good to use chemistronic flux off es835b for flux remover?
                        by chth96
                        I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                        Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                        11-17-2023, 07:25 AM
                      • maamar-tdj
                        UNOWHY Y13 2022 bios password removal needed
                        by maamar-tdj
                        Hellobrothers!
                        I need to remove the BIOS password.
                        I attached the bios dump file.
                        Laptop: UNOWHY Y13 2022
                        Motheboard: EM_IG116_200B_ENE_TI_V1.0
                        Serial: IFP230136920
                        Thanks in advance!​...
                        05-14-2024, 09:50 AM
                      • ClockChip
                        Isopropyl alcohol as a cleaning agent?
                        by ClockChip
                        Hello All,
                        I wanted to check with the board before I do anything foolish and/or irreversible. Can someone please set me straight on the use of isopropyl alcohol to clean electronics? I understand it is commonly used to clean electrical contacts. However, in this case, I am wondering if I can safely immerse a small electronic item in alcohol provided a) all power has been removed and b) I take care to dry it thoroughly before re-applying power.
                        The short version is that I am seeking to clean an older used (well-used) electronic item. The basic plan is to immerse it in...
                        03-16-2024, 12:10 PM
