Pls help identify weird black polymer caps
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    Could those can really be a Nichicon polymer FP 5K series caps, 270uF 16V?
    Because the color does not match and I know of no "5K" serie of these caps.
    Only know of FPCAP series E5 and R5, nothing more with "5", futhermore none of these are made in 270uF 16V - ONLY L8, PS and R7 series. AND they (FP L8 on picture) look quite different:
    http://s16.postimg.org/d7kgn6t9h/Gigabyte_R9200_16.jpg
    So, what the hell is this?!
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
  • mariushm
    • May 2011
    • 3799
    Re: Pls help identify weird black polymer caps
    They are Nichicon FP, but it's most likely a custom order for Asrock (or who made this board, it looks like Asrock).
    • Clutchbox
      Cap Clutcher
      • Sep 2011
      • 41
      • The Netherlands
      What mariushm already said, they are indeed Nichicon FP.
      The 5K (or 10K) addition stands for 105C 5000Hrs (or 10000Hrs), standard FP caps (with red markings, L8 series) do 2000Hrs.
      They are custom caps for Asus, maybe other manuf. & Asrock also (but i've seen Asrock just with other 'gold coloured' caps, no FP's).
      • trodas
        • Jan 2006
        • 770
        • Czech republic
        Interesting, never heard about it. And can we determine the series from the 34Ao text...? Or we have no way to know, what series they are, if these are custom made?
        I mean - specs What specs are these - long life ones, as you say?
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Seems like they may have been painted, or like mentioned multiple times, custom ordered.
          Muh-soggy-knee
          • Perry Babin
            How do organic polymer caps compare to liquid electrolytic for reliability
            by Perry Babin
            I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
            If not organic polymer, what would be the caps that could take the most abuse?
            08-18-2025, 04:04 PM
          • briztech
            identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF
            by briztech
            Hi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
            07-25-2024, 06:18 AM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
