Panasonic CE series after 30 years
  • theokretes
    • Jul 2013
    • 49
    After recapping the Roland JUNO-60 and JUPITER-4-- all of the Panasonic CE series capacitors have leaked out of the seals [always] at the right lead.
    While I love Panasonic capacitors, this shows that after 30 years these things need to be replaced and DO NOT have magical abilities to make the synths sound better. The sound improved *after* the recapping.
    From the JUPITER-4, this one unfortunately ate traces on the controller board which I repaired:
    These four came from the JUNO-60:
    Thankfully I had some RX30s on hand in 47uF and replaced them all:
    I was not able to recap the bipolar electrolytics yet because... those aren't easy to find.
    Here you'll see the blue panasonic bipolars (notice they don't have positive/negative markings unlike the nearby black sanyos):
  • lti
    • May 2011
    • 2557
    Re: Panasonic CE series after 30 years
    I don't understand why the sound quality wouldn't improve after replacing bad caps.
    • cheapie
      null
      • Jul 2010
      • 849
      He said in the post you quoted that recapping made them sound better.
      • y_not
        Same 'ol Song
        • Aug 2009
        • 147
        My 1st thought was that the poster "IT" may have just been being sarcastic when he/she posted that comment.
        Maybe not.
        How to properly apply thermal grease - Y_not's way.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          of course replacing the bad caps should make it sound better!should perform like it was new again.electrolytic caps are the only thing in a synth that degrades over time.
          you just dont notice it till its really bad!
          • PeteS in CA
            • Aug 2005
            • 3583
            • USA, Unsure of Planet
            While I love Panasonic capacitors, this shows that after 30 years these things need to be replaced ...
            That's just the nature of electrolytic capacitors. Their liquid electrolyte gives electrolytic capacitors wear-out mechanisms that film or ceramic capacitors do not have. That's true regardless of vendor - Panasonic, Nichicon, Rubycon, UCC, Marcon, Sprague, CDE, Mallory, Elna, etc..
            PeteS in CA
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Yep. The electrolyte can dry out, and the audio will be weak or tinny.
              I have seen many old capacitors like these (from different brands). They do leak after a while. It is part of the normal aging of the capacitor.
              Muh-soggy-knee
              • y_not
                Same 'ol Song
                • Aug 2009
                • 147
                I wanted to add....
                That is an absolutely beautiful circuit board, a work of art!
                I can't stop looking at it for some reason. Thanks for the purdy pics!
                This is a synthesizer, like a keyboard, not a sound mixing board, right? How many layers is it?
                • lti
                  • May 2011
                  • 2557
                  It sounded like someone told him that the old caps would have sounded better than new ones.
                  • theokretes
                    • Jul 2013
                    • 49
                    Originally posted by y_not
                    I wanted to add....
                    Yeah those circuit pictures are from the JUNO-60, the main board is (to my surprise) dual layered. Other boards are single layered, like for the bucket brigade chorus: this is what provides the majority of its rich creamy sound.
                    Because the sound generation circuitry is analog and not digital-- the components are laid out a lot differently than what you'd normally see.
                    Here's an audio sample if you want to hear some of its basic sound output:
                    http://www.youtube.com/watch?v=txhHsvAKZcs
                    Also, my JUNO-60 still has its original 1982 lithium ion battery. It hasn't exploded yet and still holds the patch memory. I really ought to change it out soon though. I keep telling myself that :p
                    This is correct, some "audiophiles" will tell you that the original capacitors are better than new ones.
                    Go read a few threads on gearslutz and you'll see people state that the original caps make the synth sound better, or are manufactured to a higher quality than what is available today. All of that is false.
                    As the capacitors age, their electrolyte fades. And they can dry up.
                    • hugocarmo
                      Panasonic TX-24A1UN CRT Sound and Input problem.
                      by hugocarmo
                      Hi.
                      I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
                      It is imaculate inside, almost no dust or debris inside.
                      The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
                      So I started to look for a service manual, I found one, and started from the beginning.
                      Most of the times the caps are the problem so I orderer all the caps for all boards,...
                      04-26-2025, 07:45 PM
                      ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 03:28 PM
                      ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      ASUS Pro Series D320MT-TR362D Pro Series i3-6100 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                      This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
