Motherboard speaker -clicking-
  • dballanc
    • Jan 2007
    I replaced a couple of damaged caps, and now the onboard speaker clicks constantly. Swapping the PS made no difference. Do I have more caps toasted, or is something else going on?
    Long story:
    I was doing some spyware cleanup for a friend who had been having some lockup problems. It also seemed to blank and die when not actively used (even after disabling all power management I could find in OS and BIOS).
    The cleanup went fine, but when I went to turn the machine on again after being away for a few days it wouldn't post at all. I reset the bios, unplugged devices (including the PS from the motherboard to drain all power). No luck. I swapped in a different PS and within a few seconds I saw two of the motherboard caps buldge and squeal a bit. I pulled the power asap and let it sit, thinking I fried it and was going to be replacing the board. I haven't dared use that PS on anything else, so I don't know if it was board or PS causing trouble.
    After the holidays, I hooked it up one last time tonight and ran fine. I thought it was my lucky day, and so I spent a few minutes digging around my dead MB box and found two 10v 1500uf caps (the same spec as the buldged ones) and used those.
    The system seems to run fine, but the sound coming from the PC speaker is just about like what you'd hear from a kid with a playing card in his bike spokes.
    I've looked carefully at all the other components and don't see any visible damage. Any pointers? Or should I just bite the bullet and replace the board?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Motherboard speaker -clicking-
    i wouldnt recommend to trash the board until you have tried replacement with new caps. Are you sure that you cleaned up all the spyware cos i remember one had a component which was clicking the pc speaker periodically. is that happening in bios also?
    • dballanc
      • Jan 2007
      I'm sure it's not software. Even with all drives disconnected it will start the clicking. The funny part is that the clicking is directly affected by what the computer is doing. It's silent for the POST, then as soon as the boot process starts so does the clicking. During the network boot attempt (when drives are disconnected) it stops for several seconds, but when the network boot fails it starts again.
      Thanks for the advice!
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        is it still clicking with speaker disconnected?
        • dballanc
          • Jan 2007
          No. It was one of those micro-speakers soldered directly to the board, but I removed it to check (and to keep sane). If it was my machine it would be problem solved. I finally thought of a better way to describe the sound: it's exactly like one of the old quantum bigfoot hard drives doing a defrag.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            well thats quite a bit of clicking then
            gonna have to recap all caps 1000uf and above with new caps and see if that solves the problem.
            is that a network card you are using or is it onboard?
            what board is this anyway.
            • dballanc
              • Jan 2007
              The NIC is a 3com 905 PCI Card. Not sure about the motherboard. It's from a Gateway machine, P3-933. I don't have it in front of me here at work, but I'm pretty sure it is a GATEWAY BROOKINGS MS-6312 FLEX ATX BOARD, MS-6312 (going by google and specs).
              I don't remember it making the sound immediately after replacing the caps, so I might have damaged them removing from that dead board. I'll put together a cap shopping list.
              edit: While googling this board to find replacement costs, the SECOND! link was back to badcaps.net. This board has a bad rep it looks like:
              https://www.badcaps.net/forum/showthread.php?t=123
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                i was wondering whether you put the nic in the other pci slot this time and there was some wierd conflict.
                caps get heated a bit too much when you remove them from one board and install on another. they still work but its not the best thing. also maybe the old caps you used were not in very good condition anyway.
                i dont think you were too heavy with the board, its still posting. check though to see that you did not knock off some small smt component or scratch/lift a trace.
                • Rainbow
                  • Aug 2005
                  • 1375
                  As it's a MSI board, it might require replacing the small 10uF and 47uF SMD electrolytic caps (if they're there). They often go bad without any signs.
                  • glovecaps
                    by glovecaps
                    11-25-2024, 04:23 PM
                  • Docus
                    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                    by Docus
                    Hi everyone 😀,
                    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                    1. I already own the exact same model, but its plastic chassis is badly damaged.
                    06-10-2025, 04:24 PM
                  • nbnb
                    Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
                    by nbnb
                    I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
                    Any idea what is causing the clicking sound? Any easy way to...
                    11-23-2019, 12:03 PM
                  • Archimedes
                    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                    by Archimedes
                    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                    Fans are spinning. Blindly could install windows11 and got the device manager...
                    07-30-2024, 05:14 PM
                  • dragon3x
                    by dragon3x
                    power on.
                    Here are some examples :
                    switching supply area).
                    than 6.3 V.)
                    03-21-2025, 02:46 PM
