I have a basic 6" bench grinder which I can stop from spinning with very little pressure. When first turned on I can easily spin the wheels backwards with one finger. It basically does not work. I was about to give up on it and I thought I would open it up. Got to reading about capacitors, uf/MFd, voltage and the like. It has a 6uf, 250VAC capacitor. When running my multimeter shows 190VAC. Could the capacitor be the problem? Thanks.
Is the problem my capacitor?
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by pkslowkSr. Motherboard Debug Error Code Solution
1 Intel 845 E9 Bios Related Problem
2 Intel 845 D4 CPU Socket Related problem
3 Intel 845 37 Bios Related Problem
4 Intel 845 7C Bios Related Problem
5 Intel 945GCPE 34 Bios Related Problem
6 Gigabyte 845 2 Ram Related Problem
7 IBM Server A6 A7 Ram Mismatch Problem
8 Asus 845 29 CPU Related Problem
9 Lenovo I946 97 C-Mos Jumper related
10 Gigabyte 845 A0 CPU Related Problem
11 Asrock G31M-VS D7 Bios Related Problem
12 Compaq 845 BD-70G B0 CPU Socket Related problem... -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
I know that these capacitor will not last as long as nichicon capacitor...-
- Loading...
