Please help me decide replacement capacitor
  • biatche
    • Apr 2012
    • 27
    • Malaysia
    ORIGINAL CAPACITOR:
    EPCOS 1000uF 16v 10x20 0.054ohm 1100mA
    REPLACEMENT:
    choice 1: 0.019ohm 2180mA
    choice 2: 0.052ohm 1220mA
    choice 3: 0.023ohm 1820mA
    which to pick?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Please help me decide replacement capacitor
    What did the capacitor come out of? It depends but I would choose the 2nd option as it's closest to the original specs. What brand are the replacements you are looking at?
    • biatche
      • Apr 2012
      • 27
      • Malaysia
      monitor
      replacement caps: panasonic
      Some people on IRC are telling me choice1/3 is better.
      • mariushm
        • May 2011
        • 3799
        Considering you don't say the brands, we could only guess.
        The other choices may be better, for some specific uses (vrm circuitry in motherboards, more complex power supplies), but if your original capacitors had those specs, you don't gain much by using capacitors with way better specs.
        On the contrary, those capacitors with better specs may have shorter life (let's say 1000h@105c versus 2-4000h@105c for option 2) and life rating actually has more relevance in some cases. like monitors where everything is closed with little ventilation room.
        • biatche
          • Apr 2012
          • 27
          • Malaysia
          choice 1: 0.019ohm 2180mA PANASONIC
          choice 2: 0.052ohm 1220mA PANASONIC
          choice 3: 0.023ohm 1820mA PANASONIC
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            The point P4 and mariush are trying to get across is that this is not as simple as you might hope. Value, case size, impedance, ripple current rating, brand, and circuit function (not just the product its used in) all matter. Try being a little patient and maybe learn a little from guys who have been doing this for years or even decades.
            PeteS in CA
            • biatche
              • Apr 2012
              • 27
              • Malaysia
              Hm, perhaps its my misunderstanding.. but would you mind telling me when replacing PSU / monitor PSU caps, what are the things to look at then for a more prolonged lifespan? Is it to check those 1000h@105c? I've went ahead and purchased 10,000 hours @ 105c with lower ESR, higher ripple... Please correct my mistakes
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                That is good, that's what you want is a long life span @ 105C, low ESR, and high ripple. As long as they fit then those caps should be perfect. Try and get the dimensions as close as possible. But just to be sure what series are those Panasonic caps?
                • biatche
                  • Apr 2012
                  • 27
                  • Malaysia
                  I've already purchased and received the following (for various monitor repairs):
                  EEUFR1E102 CAPACITOR, RADIAL, 25V, 1000UF EEUFR1E102
                  EEUFR1V681 CAPACITOR, RADIAL, 35V, 680UF, 20% EEUFR1V681
                  EEUFM1A102 CAPACITOR, RADIAL, 10V, 1000UF EEUFM1A102
                  EEUFR1E821 CAP, ALU ELECT, 820UF, 25V, CAN EEUFR1E821
                  They are all panasonic.
                  I've fixed a Samsung 931BW, and a AOC 2219VG.
                  I just did a LG-L226WTQ-PF. The screen power LED now goes standby/lights up normally when the PC turns on. The lighting is obviously turned on but there's no picture on screen. What could this mean? I should note my solder work was bad and I left burns on the pcb. ?copper? is exposed.... should i post a picture?
                  Also, I've carelessly not noted the 2-pin colors on some other monitors and have forgotten their positions. What happens when the cable is incorrectly plugged?
                  it's either:
                  [red-white] [blue-black] [blue-black] [red-white]
                  or
                  [red-white] [blue-black] [red-white][blue-black]
                  • mariushm
                    • May 2011
                    • 3799
                    The capacitors you chose are very good.
                    Use a flashlight or something bright and see if you can see something on the screen when you're supposed to be able to see something. If so, there's a problem with the backlight, either you didn't solder something properly or the problem was more than just a capacitor replacement.
                    Please post pictures, as clear as possible.
                    As for the cables, if you put them incorrectly you can cause a short circuit, blowing up capacitors or fuses on the boards. Or it could be nothing, depending where those cables go.
                    If you post pictures as clear as possible, we may be able to tell you where the cables go or in what order. Usually there are hints on the boards or the connectors are in a particular format.
                    Or someone here may have worked on that monitor (or a monitor with a board similar to yours) and remembers the cable layout.
                    • biatche
                      • Apr 2012
                      • 27
                      • Malaysia
                      2 monitors don't seem to be capacitor issue! Hmm.. they display for just a split second then picture disappears. By selecting the source from the panel, it displays again for a split second then disappears.
                      • mariushm
                        • May 2011
                        • 3799
                        It's quite possible.
                        I'll give you a simple example: the inverter circuit which converts 12-30v from the power supply to 700-1500v required by the CFL lamps (the light tubes) has a protection mechanism.
                        The controller will turn off the lamps after a timeout period, if one of the lamps doesn't seem to start or if the lamps demand too much current (which happens when the lamps are very old).
                        It's possible for a lamp to not start because one of the wires going to it becomes loose due to constant heating and cooling down cycles - it happens often. If a wire is loose, the circuit is interrupted and the controller doesn't detect the two lamps using power so it stops completely after that time out period.
                        If a lamp is very old and demands a lot of current, the controller could also detect that and stop itself to protect those rectangular transformers from overheating, or to protect other components in the inverter circuit.
                        Since there are usually two outputs and usually there are tubes (lamps) connected to each output, the controller could stop itself even if one lamp is faulty.
                        Capacitors can go bad for example when one or several lamps go bad in time and demand more current from the controller which in turn could overload the controller and get it hot and in turn puts more stress on the capacitors... could also be the other way around... the capacitors going bad and messing up the inverter (and you may have soldered the new capacitors badly so it still doesn't work) ... who knows.
                        There's lots and lots of possibilities.
                        Please get back to use with pictures, as clear as possible.
                        • biatche
                          • Apr 2012
                          • 27
                          • Malaysia
                          There are 2 monitors I'm unable to repair:
                          LG L226WTQ-PF:
                          capacitors replaced
                          bad soldering work, pictures to come soon. waiting for camera
                          light tubes go on and off normally when monitor is on/off, however, no picture can be seen
                          Samsung 931BW:
                          nothing's changed.
                          capacitors not even bulging, looks good.
                          picture displays a split second then disappears. selecting source causes it to display for a second then disappears again.
                          found someone else with this issue. this does not look like easy work:
                          http://www.jestineyong.com/samsung-9...second-solved/
                          • biatche
                            • Apr 2012
                            • 27
                            • Malaysia
                            LG L226WTQ-PF (MY BAD SOLDER WORK):
                            Backlight is on but no display.
                            Pressing on menu button doesn't show anything. Actually none of the buttons do a thing -- zoom, source, menu, etc etc.
                            Turning on and off does show the LG logo middle of the screen. Very clear.
                            Also displays source at top right corner. Very clear.
                            • biatche
                              • Apr 2012
                              • 27
                              • Malaysia
                              LG L226WTQ-PF more pics and vid:
                              http://cockcrotch.com/tmp1/tmp-bunder-1.jpg
                              http://cockcrotch.com/tmp1/tmp-bunder-2.jpg
                              http://cockcrotch.com/tmp1/tmp-bunder-3.wmv
                              • biatche
                                • Apr 2012
                                • 27
                                • Malaysia
                                SAMSUNG 931BW:
                                http://www.cockcrotch.com/tmp1/tmp-brownspots-1.jpg
                                What are these brown spots? there are several spots like this. should it be resoldered? could this be the cause?
                                • mariushm
                                  • May 2011
                                  • 3799
                                  The LG looks fine.
                                  If it shows those "no signal" messages and the backlight stays on that long, everything's good.
                                  Since the monitor has both vga and dvi, make sure it's switched to the proper source (that may be the cause for the no signal message).
                                  If you're using a dvi to vga adapter, make sure the video card's dvi connector outputs analogue signal - some video cards have two dvi ports but only one outputs vga.
                                  If you're sure the monitor is supposed to get a signal (you can test this by checking with another monitor), then something between the vga or dvi connector and that large chip could be damaged. Possibly due to ESD or a short circuit etc.
                                  The board otherwise looks fine to me.
                                  If you have a multimeter, put it in DC voltage measurement and measure the voltage on IC702 and IC703 ... Black probe on center pin, red on the first, last and the tab (that large part soldered to pcb like a heatsink)
                                  It's unlikely one of those 2 voltage regulators is bad but it doesn't hurt to try.
                                  The Samsung monitor, it could use some cleaning.. get some cloth and remove the dust.
                                  The brown stuff could be flux left from the wave soldering process, it's not something that would cause problems.
                                  However, there are some solder joints that look like they could be cracked or cold solder joints (from vibrations, heat-cold cycles etc).. the ones at the top and the one by R76 and C9 don't seem so good to me.
                                  It wouldn't hurt to at least reheat that solder with your iron tip (ideally remove the solder and put new solder).
                                  Clean up the board and post pictures of the whole board and pictures with different sections more zoomed in like in the lg pictures
                                  • MORETTIGIAN
                                    Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                    by MORETTIGIAN
                                    Title:
                                    Description:
                                    During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                    I did not notice it detaching, so I am unsure of its original location on the PCB.
                                    Procedure performed:
                                    - Removed backplate
                                    - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                    - Reapplied thermal compound
                                    - Reassembled card
                                    Observed behavior after reassembly:
                                    - GPU powers on and operates normally under...
                                    09-18-2025, 12:14 PM
                                  • artvandalai
                                    Where can I get compatible capacitor for replacement?
                                    by artvandalai
                                    Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
                                    12-28-2024, 10:15 AM
                                  • r2digital
                                    klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                                    by r2digital
                                    I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                                    04-18-2024, 03:50 PM
                                  • rwkish
                                    Discontinued Capacitor looking for Replacement
                                    by rwkish
                                    Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
                                    08-18-2024, 06:54 PM
                                  • Hylax
                                    Replacement capacitor options please?
                                    by Hylax
                                    Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
                                    08-09-2024, 11:25 PM
