HI first off , i know nearly nothing about capacitors, but i do know a bit about pc's.
OK so heres the deal. I just bought a pc(without HDD) Of a guy in my town.
The thing is ,it wont start up. The guy I baught it off said it wouldnt start up when here tried but said it was something to do with the power button not being wired up right.
I now know that the power butten does indeed funtion correctly as i used it to start up my old (crap ) pc. the new pc's specs are as follows
AMD athlon 64 3200
512MB ram
OLD 40 gig samsung HDD from my old rig.
Radeon 9600xt
epox 8kda
(supposedly) 400 watt psu.
When i attempy the turn it on , absolutely nothing happens<not even the fans spin up, even in the psu.
However. i was pullint out the mobo power leads while the psu was still on (obvoiously i didnt realise it was still on) Once i had taken out the 4 pin connecter, and was in the process of taking out the 20 pin power connector the trouble shooting LEDS turned on for a second or two.What do you guys recon?
Does anyone have any ideas?
I think it may either be that the POwer supply is not strong enough.Or that the MOBO is fried.
There are no visible burn marks or anything on the mobo.
Ok i jsut noticed that there is a capacitor down near the mobo chipsetthat gets really hot, when i turn on the psu, even though the PSU fans doenst turn on. Do you think if I connect the two capacitor pins then the pc might turn on??Or will something blow?
Is it possible that maybe that there is something wron with that capacitor? It heats up really quickly . It says EC5 beside it if that makes any difference to you.
Any and all help is much apprecitaed
cheers
chris.
sorry about the crap quiality.
AMD athlon 64 3200
512MB ram
Radeon 9600xt
epox 8kda
cheers
chris.
