spec sheet needed
  • zubbly
    • Nov 2006
    spec sheet needed
    hey alll, new to the board.
    just hoping someone can help
    need spec sheet on following capacitor
    MEPCO/ELECTRA
    3110DC112T200BMA1
    1100MFD200WVDC
    362-8237
    any help would be most appreciated.
    thanks,
    zubbly
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: spec sheet needed
    welcome
    if spec sheet not available
    what device is it installed in?
    is it 85oC or 105oc part?
    • zubbly
      • Nov 2006
      hi willawake!
      thanks for responding.
      there is no temp rating on the capacitor.
      i am using these in a wind generator, between the gen and heating elements that are powered.
      it is the ripple current rating that i need to know.
      thanks,
      zubbly
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        I tried to find info on this, without luck. FWIW, Mepco/Electra was bought some 15 years ago by Philips. I would suggest not using this part, as it is more than 24 years old - 8237 = 37th week of 1982. I would suggest finding a 1000uF or 1500uF, 200V part from United Chemicon, Nichicon, Panasonic, or Cornell Dubilier in a similar case style. Technology has advanced sufficiently in the past 20+ years that you will probably end up getting a better part.
        PeteS in CA
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • Digighost
          MSI GS76 STEALTH 11UG No Power (Please tell me I didn't kill my baby!)
          by Digighost
          Hello Everyone Please bear with me as I'm not very experienced in electronics and board repair but I think with a little help from you experienced guys I can get this done. I do have a tech background and I believe I have all the needed equipment to complete the task at hand.
          A week ago my MSI GS76 STEALTH 11UG (board MS-17M11) No easy way to say this I think I may have killed my baby. What had happened was My ALFA External Wifi was not being recognized because it needed more power than my machine could output. After researching the issue I found out that using a powered USB hub...
          08-27-2023, 09:54 AM
        • Wild7
          ITE IT8587E Data sheet needed
          by Wild7
          Having trouble locating a data sheet for an ITE it8587e. Found a few links here via search, but they appear to be broken now. Any help would be appreciated. TIA
          05-14-2020, 06:13 AM
        • Lee M.
          LG 55LN5710 backlight diffuser sheet order
          by Lee M.
          Hello all, new member here. I replaced the LED strips and found that the BL can be turned on with the TCON board and LCD panel disconnected. So new LED strips are working fine. Now the problem. There are 3 diffuser sheets on this set. One sheet is thicker than the others and I know it goes in first next to the LED strips. But one side of this sheet has a rougher texture than the other side. Does the rough side go up or down? The 2 thinner sheets have tabs that will only allow them to be installed one way so that's good. One sheet is what I would call plain translucent. The other sheet is whiter...
          11-29-2021, 07:52 PM
        • Darren Hibbert
          Lenovo Y50-70 LA-B111P Boardview needed
          by Darren Hibbert
          08-09-2025, 06:01 PM
