Wrong size caps, what can you do?
  • SonicSteve
    • Oct 2005
    • 54
    Hi guys,
    I have some boards with 3300uf 6.3v caps on them. All OST and I want to replace them.
    Problem though,
    They are all 10mm Diameter and very close together in many places.
    The ones I can find to order are 12.5mm diameter and I doubt that they will fit in such tight spots.
    I've searched 3 distributors and none carry suitable capacitors in the diameter that I need.
    It seems that once you go over 2200uf the diameter is almost always 12.5mm or larger.
    Does anyone have a solution to this?
    I've looked at united chemicom, nichicon, and panasonic. None of the suitable series have the right size.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Wrong size caps, what can you do?
    topcat can get you 3300uf 6.3v 10mm caps. Also, Samxon makes a suitable replacement.
    Ludicrous gibs!
    • gonzo0815
      • Feb 2006
      • 1600
      Where is your loaction?
      In generall, you can bent or angle them, but this needs some room.
      • yanz
        • Nov 2004
        • 910
        Originally posted by SonicSteve
        Hi guys,
        Problem though,
        unfortunately that's true. these are the only 10mm 3300uf 6.3v i can find on the datasheet:
        https://www.badcaps.net/forum/showpo...5&postcount=12
        i have the sanyo wg, iirc big pope (joe) too. topcat have the mbz. mcz can be found at wai fong (china) iirc.
        [quote]
        Does anyone have a solution to this? [quote]
        i would recommend to use 2700uf 6.3v 10mm caps (god brands) if you can find them to replace those 3300uf-ers.
        days are so short when you actually do something..
        • gonzo0815
          • Feb 2006
          • 1600
          Depending on the motherboard desing, i would not replace 3300uf caps with lower ones. Especially the AMD soket A platfrom, with only 4 3300uf caps are sensitive for that. I have had no luck on a K7s8xe+ with 2700uF Oscon. 4x 3300uF is just not mutch margin to reduce it. The ESR is on those boards very important too. Any negative change will cripple the transient behaivior. I would certainely loock to obtain the correct caps for those boards. I think TC or BigPope are the way to go. Waifong`s MCZ are not bad too, and reliable service.
          For those other boards, with unpopulated silkscrean, you can use 2200Uf caps and adding the missing ones.
          • bgavin
            • Jan 2007
            • 1355
            I just purchased 250 pieces of Rubyicon from Wai Fong. They charged $20 USD for Express Mail shipping, and it hit my doorstep a few days later.
            Packing was safe and secure, and all items were received. Web site ordering is painless. Due to shipping costs, USA buyers should make bulk orders to avoid paying high shipping costs for a few items.
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
              by momaka
              03-12-2025, 03:42 PM
              by momaka
              03-15-2023, 10:17 PM
            • flibidy
              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
              by flibidy
              I have here a Magnum IA.100 which belongs to my parents.
              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
              What Ive done........
              01-01-2025, 01:26 PM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
