Caps for Samsung LN-T4065F Power Supply
    I've pulled 7 bulging and or leaking caps from the power supply of my TV and need some direction on locating replacements. I have several with the same voltage and micro fared rating but different sizes. Thanks for any help pointing me in the right direction
    They are labeled as follows:
    WB 25V 1000uF V2A pet
    WB 25V 1000uf U9E
    WB 10V 1000uF V2A (four of these)
    RD 25V 220uF U7C
    Re: Caps for Samsung LN-T4065F Power Supply
    Oh...Samwah is the Manufacturer.
    Just found this thread...
    https://www.badcaps.net/forum/showthread.php?t=12922
    So I now understand the WB and the RD are the Series.
    Where to buy? Are they available here?
      You don't want to buy Samwha capacitors, they're not of good quality. You probably wouldn't find WB series anyway, I think it's discontinued.
      You buy capacitors with same or better technical characteristics from a better capacitor manufacturer.
      Panasonic FM or FR will work just fine instead of both WB and RD.
      You can find those on Digikey.com or Mouser.com or Newark.com ... check the badcaps.net store as well. I'm only going to give links for newark and digikey
      1000uf 25v
      http://www.digikey.com/product-detai...425-ND/2433559
      http://www.digikey.com/product-detai...424-ND/2433558 (same as above but a bit smaller in height)
      http://www.digikey.com/product-detai...2379-ND/613740 (cheaper than the two above, but make sure you can fit capacitors that are 12.5mm in diameter like this one. if not the ones above work and they're 10mm)
      http://www.newark.com/panasonic/eeu-...25v/dp/74R3428
      http://www.newark.com/panasonic/eeu-...25v/dp/04M9016 (12.5mm diameter)
      220uf 25v
      http://www.digikey.com/product-detai...2383-ND/613744
      http://www.newark.com/panasonic/eeu-...-20/dp/04M9017
      1000 uf 10v
      http://www.digikey.com/product-detai...2353-ND/613714 (10mm diam.)
      http://www.digikey.com/product-detai...2354-ND/613715 (8mm)
      http://www.digikey.com/product-detai...378-ND/2433512
      http://www.newark.com/panasonic/eeu-...10v/dp/04M9004
      http://www.newark.com/panasonic/eeu-...10v/dp/74R3403
        Awesome! Thanks for the reply. I was struggling with the series info. I also measured them all.
        I have 1000uf 25v that are 12.5 x 20 and 10 x 20 the 10000uF 10v are 10 x 16 and the 220uF 25v is 8 x 12.
        Thanks again for your help.
          Use /store instead of /forum in browser URL to visit store.
          These Rubycon capacitors at Badcaps.net store probably suit for your purpose, you can check/choose yourself by studying datasheets (use google).
          1000uF 25v 10mm ZLJ Series
          220uF 25v 8mm ZLG Series
          You can use 25v caps instead of 10v caps, if they are not too big physically.
            My TV is working! I would never have tried to fixed it myself without the information from this site. Searching the forum I found information detailing similar problems along with pics and info posted by Budm. I purchased the Panasonic caps recommended by mariushm and installed them. In a couple of hours and $10 later it works perfectly!
            Thanks for all the time you guys give!
