VP930b Cap replacing
  • Pepper
    • Mar 2013
    • 11
    • Malaysia
    i am literally a newbie and never touch a solder gun in my whole life before but now im going to try to fix an old monitor of mine by following the steps from this thread here
    https://www.badcaps.net/forum/showthread.php?t=5537
    i am able to identify what i will need to get
    1000uf 16v EEU-FC1C102
    470 uf 35v EEU-FC1V471B-ND
    220 uf 25v EEU-FC1E221
    but i have no idea which i should get for the
    100uf 400v capacitors
    since im practically half a world away from America so i will be using a local website here in my country.
    i dont know which one i should go for
    im afraid if i put them in , it will screw up the PSU
    Panasonic? since i cant find the FC series for it
    http://malaysia.rs-online.com/web/p/...itors/0575355/
    http://malaysia.rs-online.com/web/p/...itors/0575361/
    http://malaysia.rs-online.com/web/p/...itors/0575321/
    http://malaysia.rs-online.com/web/p/...itors/6997562/
    or Rubycon? its a lil' pricey
    http://malaysia.rs-online.com/web/p/...itors/7497240/
    http://malaysia.rs-online.com/web/p/...itors/7047778/
    p.s. i have no idea what kind of solder wire i should go for either :/
    help is much appreciated
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: VP930b Cap replacing
    Hi - You should not need to replace the BIG cap unless it is obviously swollen leaking or damaged.
    You should be using a soldering iron 40 - 60 watt with a fairly fine point or chisel tip for changing capacitors.
    You will also need either a desolder pump or some soldermop (braid) to remove old/excess solder.
    You also need some flux.
    Solder wire - get leaded if possible 60/40 with flux in it.
    Practice soldering on an old electronics item if you have one or even just on pieces of wire.
    There are number of videos on youtube or even links on this site - type soldering
    into the search.
    • Pepper
      • Mar 2013
      • 11
      • Malaysia
      thank you for the info :U
      the big cap is now bulging tho
      ill research more on the soldering iron tho eventho i got one cheaply
      and a desolder pump too
      flux however eludes me, leaded solder wire 60/40 flux, i will have to find that too
      thanks for the advice :U much appreciated
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Sorry Missed your reply - Are you sure the Big cap is bulged - sometimes its just the plastic plate at the end - if you can press it in easily it is ok. If you can I would go for this one http://malaysia.rs-online.com/web/p/...itors/6997562/ much better ripple.
        Solder- often expensive to buy on line because of the weight/postage. You wont need a lot try to get it locally but if not this should do
        http://malaysia.rs-online.com/web/p/solders/0557792/
        • Pepper
          • Mar 2013
          • 11
          • Malaysia
          if only i had read your message earlier,
          i might had saved some money
          I had fix the VP930b replacing all the badcaps with panasonics except for the big cap which i uses rubycon.
          i bought the solder lead 20 bucks more expensive than the one you suggested, if only i had read it earlier i would had just stick to yours
          and since there's an RS in my country, the transport fee is free and often arrive the next working day.
          none the less the VP930b is fix, so is my other monitor the VX1932wm
          which both i am currently using atm. i'd replaced the caps wit hthe same uF but some with higher voltage from like 10v to 16v or 25v to 35v. their color calibration are bad since they have being with me for more than 4 years.
          i am now going to tackle the t240 samsung which i will open a new thread soon since i cant identify the caps
          thank you for your information and support.
          • Northeastern292
            • Jul 2009
            • 15
            On a personal note, I've recapped a few VP930b's with success, except for one I might have to go over. I've noticed a few Viewsonics that have had the plague bad.
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • SluggerB
              Would this be safe?
              by SluggerB
              I am trying to fix a broken plasma TV by replacing a large cap on the power board. It is a 1900uf 220v cap and I could only find one place that sells them. It was listed as through hole, so I bought it. It showed up today, but instead of through hole, it has spade connectors.
              Would it be safe to get some heavy duty wire (like lamp cord wire), connect that to spade connectors, connect them to the spades on the cap, and run the other ends of the wire 2-3 inches to the holes and then through the holes and solder them in place? I actually did it already and put it together but...
              06-04-2025, 04:22 PM
              Multifix 425-01 and 450-01 Rework Flux Datasheet
              REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
              - No Clean Formulations
              - Low residue
              - Range of activity to deal with different component solderability
              - Halide free
              - Suitable for dispensing
              - Compatible with solder coatings and/or No Clean flux cored solder wire product range
              Both products are supplied in syringes or cartridges for application by dispensing....
              10-07-2024, 06:02 AM
            • wnlewis
              New wire for my RDE3340 Whirlpool electric range
              by wnlewis
              OK. I got the rocker switch figured out thanks to the good advice on this forum.
              Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
              This is a Whirlpool RDE3340 electric range.
              The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
              Where may I find parts...
              01-08-2025, 11:21 PM
            • Eaglecrest
              Whirlpool dryer control board
              by Eaglecrest
              I have a Whirlpool dryer that runs for a while then stops with a blinking timer screen. The dryer can't be reset by hitting any input and if you pull the plug and plug it back in it also won't respond. Light is on in the drum when you open the door, but no other sign of life. If I leave it unplugged for a period of time, which is multiple days, it runs again. May be able to get a load done, but now seems to be less than full load before it errors out.
              Since unplugging will get it to work, I am assuming that there is an error condition that is causing the onboard processor to shut...
              11-05-2025, 07:09 PM
