Okay so lets just start off by saying
1.) I'm a girl
2.) I'm blonde
3.) I'm NOT a computer/TV wiz so please don't use jargon I can't understand.
4.) I'm a pilot so I'm not stupid - I can learn....just SPEAK SLOWLY lmao
Okay, so I inherited an old plasma tv from my grandfather. The moment I got it home, plugged it in, a poof of black smoke came from the back, and the picture went black. O.o
So I have this AWESOME friend
who did mega research and found what the issue was, and came over and we knocked it out. Worked great. Bad Caps that were responsible for the picture - wedged in between a heat sink and....the name ecapes me but the little power things. lol...
So about a year goes by, and it happens again.. I figure. Hmm not so hard to do, so I went and bout four more caps, a soldering gun, and replaced the two caps that had blown before - even though they hadn't violently exploded this time.
SO now it's about 2 years later, and my son was watching a show,
paused the TV, came back and the picture is now...dark. You can still see stuff moving around, but it's REALLLY dark.
My friend has gone AWOL and I can't find him. =(
So I figure caps are bad again. Wrong. I replaced those two and it didn't change things - actually now I've lost all sound now!
So I read up on this and see that the ZSUS board is responsible for the bad/dark picture - but the sound is on a different board?
What the hell happened
and is this 10 year old tv worth saving?
I took pictures of the boards, and whatnot but didn't posted them, as I haven't' got them of my phone yet.....but I have #'s off them. I inspected all areas, and nothing looks bad EXCEPT....right by the caps that go bad, there is a.....flaw? in the green plastic part of the board. It's slightly bubbled up but not burnt. (I tried taking a picture of it, but it's so slight you can't see it.) the back of the board looks fine. The rest of the tv looks fine.
There is a green LED light on the back that blinks when I push ON.
When I unplug the right (Zsus board) I get a blue screen (still faint though) if I unplug the right board, picture froze and I couldn't get it to come back. Still no sound, but admittedly it "COULD" be muted, or something...I can hear static....Or like a clicking through the speakers when I turned the DVD player on and off. Both boards buzz when it's plugged in, but the one on the right (If you're standing behind the tv) doesn't get hot.
There is not a fan inside this puppy which I thought was odd. I cannibalized
an old computer of useful parts and kept a CPU fan. If I get this thing fixed, I noted some power sources, on the left side of the Main (center) board - could I install the fan there, and help keep the TV cooler? Chrissakes I could bake a cake from the heat that thing throws off on a warm day.
The caps that always blow are a
22.mfd +/- 10%
NTE -F 630vdc
Board numbers are as follows
PCB code no: LJ41-0199A (Zsus board)
Model Number 50 v2.0-xm
rev no : R1.8 (03/01/22)
Main Board?
Model Name :B4k-50 Rev: 1.2 (2002.12.14)
Left board
50 v2.0 ym
PCB code no: Lj41-01200A
Rev no: R1.9 (03/04/28)
Model Code on back of TV
HPN5039X/XAA
Type No. Ax50p3
Serial no.
U533 31HW602359
Manufactured June of 2003
Thanks SOOOOOOOOOOOOOOOOO much in Advance!
1.) I'm a girl
2.) I'm blonde
22.mfd +/- 10%
NTE -F 630vdc
Main Board?
Left board
50 v2.0 ym
HPN5039X/XAA
Type No. Ax50p3
Serial no.
U533 31HW602359
