Capacitor Values?
  • ChaosBlizzard
    • May 2004
    • 32
    Capacitor Values?
    I have a vp6, I wanted to replace capacitors that have 1000UF and 1500UF raings. My question, what is the point of installing capacitors with higher UF values?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    There are no big gains. I would stay with the original values. For some pointers should you decide to change, take a look at this thread....
    https://www.badcaps.net/forum/viewtopic.php?t=112
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • rashidjafar
      Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
      by rashidjafar
      I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
      Values for :-
      PC43 : Capacitor [3x1.5mm]
      PL7 : Inductor [2x1mm]
      PC39 : Capacitor [1x0.5mm]
      Any ideas would be appreciated.
      I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
      08-07-2025, 05:10 PM
    • mrkmpn
      Capacitor values in boardview
      by mrkmpn
      I am trying to determine the value of a blown capacitor, and the boadview shows the values for many of the capacitors and other components on this board, but all of the information blank on others.
      Is there any relevance to the fact that some of these values are left out, or is it just inconsistency by whoever created the boardviews?
      Is there any way to deteremine if one without infrormation matches one that shows those details?
      05-25-2022, 12:03 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
