Scatronics 2200uf 16v
  • UraBahn
    Scrapheap Hound
    • Nov 2004
    • 165
    Found this in my old generic speaker system. First pic is the sleeve bearing the name. Second pic is the top of the cap. Its very hard to tell but if you look at the top in good light you can see it's very slightly bulged.
    The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
    I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
    Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
    by momaka
    This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
    Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
    Macron Power Technology Co. LTD.
    Let’s look at the PSU itself.
    The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
    06-02-2021, 10:05 PM
  • BleedCap
    OLD Socket 478 custom bracket + NEW generic cooler
    by BleedCap
    I already posted this on vogons.
    Its a 3d printed custom bracket for socket 478.
    I used this AM4 bracket as a base design.
    Its to be use with cheap generic clip based cpu cooler.
    Reason for doing this is:
    - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
    - New generic cooler is cheaper and can use bigger fan (less noise)
    I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
    The processor that I was using is P4 2.4Ghz prescott....
    11-05-2023, 08:09 PM
  • linuxguru
    Fatman iTube (aka Dared MP-5) tube-buffered gainclone upgrades
    by linuxguru
    The Fatman iTube (OEM Dared, which also sold its own-branded version, the Dared MP-5) is a tube-buffered gainclone first introduced c.2005, to target the iPod market with a bookshelf tube setup. It became a huge success over the next ~15 years, selling over ~100k units worldwide to a market where it was often their first introduction to vacuum-tube audio on a budget.
    http://www.enjoythemusic.com/magazin.../dared_mp5.htm
    One of the Fatman versions landed up for auditioning a few days ago, and I must say that I was impressed with its form-factor, pricing,...
    03-13-2021, 08:45 PM
  • linuxrunner
    generic diffuser?
    by linuxrunner
    i have a 65" samsung UN65TU700DFXZA. my kid sprayed cooking oil from a spray/mist bottle onto the screen (2yr old thinking she was cleaning). oil ran down and seeped under the bezel on the bottom of the screen. It appears to have soaked/wicked into the diffuser i have a light colored splotch along the bottom of the screen that grew upwards over a day or two.
    i have not disassembled yet but judging by the way it wicked up it looks like its been absorbed into the diffuser so i don't have a lot of hope of cleaning it.
    i checked Samsung parts site but they don't...
    08-26-2022, 10:52 AM
  • Dannyx
    Using car key fob as generic remote control
    by Dannyx
    Good day folks. It's been a while since I've DIY-d anything, so the other day I was thinking if it's possible to use the key fob of my car as a remote for other automation stuff. I have quite a few generic 433Mhz remotes and modules I picked up on Ali for various projects, but instead of having another remote dangling off the key chain, I thought I could use the car's own fob for more than unlocking my car when I'm near it. Say I come home and wish to switch on a light at my front door.
    I already tried putting one of my generic receivers in pairing mode and hitting one of the 2...
    04-18-2022, 02:17 PM
