how good are panasonic FL caps?
  • mariushm
    • May 2011
    • 3799
    Re: how good are panasonic FL caps?
    Oh give me a break.
    FJ: 1140mA ripple, 0.03 ohm esr , 8x11.5 2000 hours
    FM: 820uF 6.3V ±20% 3000 Hrs 1240 mA 0.041 Ohm 8x15
    FR: 820uF 6.3V ±20% 6000 Hrs 950 mA 0.056 Ohm 8x13
    If you think 0.03 vs 0.05 is gonna make a difference, especially since the measurements are done at 20c and the capacitors are probably gonna stay at 20c for 0.1% of their usage... or that the designed relied on FJ caps handling over 1000mA ripple...
    Yes, HM will be almost spot on, but good luck finding it in retail shops since it's discontinued. This site's shop maybe has it.
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • BigPete
      Panasonic Heatpump Dryer Repair
      by BigPete
      I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
      The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
      In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
      Unfortunately the whole machine has to come apart to fix it.
      I have...
      11-01-2025, 06:40 PM
    • madscientist750
      Replacing electrolytic caps by solid caps on old motherboards
      by madscientist750
      I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
      I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
      I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
      10-19-2025, 06:10 AM
