Teapo capacitor quality
  • Agent24
    I see dead caps
    • Oct 2007
    • 4958
    • New Zealand
    #81
    Re: Teapo capacitor quality
    At least the capacitors that came with the PSU were OK to begin with, rather than fakes, pieces of wire.
    But I agree, I replace the lot too.
    -David VanHorn
    • mockingbird
      • Dec 2008
      • 5484
      #82
      Originally posted by CapSwapper
      I always pull and toss them all. even if it's a 1uF. I don't trust any junk caps from china anymore. I once ordered some IC adapters from china and they sent me a bag of 10uF caps by mistake. the readings on every cap was zero capacitance and zero resistance. so basically they sent me a bag of jumpers disguised as caps
      What brand of caps were these?
      • richdelft
        • Dec 2013
        • 3
        • netherlands
        #83
        Originally posted by c_hegge
        I'm guessing that certain person is me. I'll stop hating them when I stop seeing them failed in 2-3yr old PSUs which have only been used in a home environment. I'd rate them slightly above Fuhjyyu, but below CapXon.
        So because they fail in a home environment, they are bad?. Don't you just have a oem psu, like most of the psu's are?.....It's an average ok cap and not cheap or something. And what is your knowledge about electronics in general? Build and refurbished a lot?
        gr. richard
        • Agent24
          I see dead caps
          • Oct 2007
          • 4958
          • New Zealand
          #84
          Yes, a home environment is not very stressful. If they can't handle that, they're pretty bad.
          -David VanHorn
          • CapSwapper
            • Feb 2014
            • 69
            It was in chinese
            • eawtan
              • Nov 2015
              • Singapore
              #86
              Bulge teapo :
              From my old silverstone op650 psu.
              • chth96
                Does WCAP-ATG5 has similar or better quality than smahwa capacitor?
                by chth96
                I want to replace samhwa RG 250v 1uf capacitor which has no ESR value and has capacitance less than 280pf.
                It is possible to purchase WCAP-ATG5 in local electronic shop.
                But I want to know that whether WCAP-ATG5 capacitor has similar or better quality than smahwa capacitor or not.
                Is there anyone who has experience to replace any bulge or faulty cap with cap from Wurth Elektronik?
                https://www.we-online.com/en/compone...ucts/WCAP-ATG5
                05-09-2024, 02:57 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
                by momaka
                03-15-2023, 10:17 PM
              • bauto601
                KDM 480W PSU upgrade succes! (opinions?)
                by bauto601
                Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                A "nice" YoungYear unit? - Badcaps
                The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                12-26-2023, 03:05 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
