Bad Caps will Affect Northbridge?
  • hanief
    • Jun 2006
    • 6
    Is it true if we leave the bad caps on the motherboard too long without care to change them, it will affect other parts such as Northbridge on the motherboard? (just curious)
    You can see some of my works here:-
    http://indiecom.net/dru/?q=taxonomy/term/15
  • linuxguru
    • Apr 2005
    • 1564
    Re: Bad Caps will Affect Northbridge?
    Yes, failing caps on the +5v, +3.3v, +2.5v, and Vcore rails can cause CPU failure as well as Northbridge failure, usually in conjunction with bad caps in the PSU.
    • yanz
      • Nov 2004
      • 910
      hanief, that link is inaccessible without password.. we would be glad to get the pics attached here..
      • tazwegion
        • Jun 2006
        • 444
        The Northbridge on a Abit KT7 I was once given had sustained damage, and despite the replacement of the capacitors it booted okay but IDE interface was stuffed (even when using add-on PCI controllers), hence it was scraped for the NB cooler
        Kinda' adds to the saying "A stitch in time, saves nine..."
        Viva LA Retro!
          by momaka
          03-12-2025, 03:42 PM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
