Bad Biostar 790gx Replacement for OST RLP 6.3 1000uf
  • anteck7
    • May 2012
    • 5
    Started having odd lock ups and such on my 3.5 year old computer. After doing the regular check hard drive run diagnostic on each subsystem and having then come up clean, I started looking over the board and power supply.
    Board has at least 2 bulgy capacitors near the north bridge (i'll get some snaps later).
    They are OST RLP series 6.3 volts at 1000uf, there are also some OST RLX 6.3 volt at 1000uf as well.
    The RLPs seemed to have been used in a high heat area (right next to NB and processor).
    What would be a good capacitor to replace them? What would be a good one to replace the RLX units? I'm in the US.
  • mariushm
    • May 2011
    • 3799
    Re: Bad Biostar 790gx Replacement for OST RLP 6.3 1000uf
    Nichicon HM, HN, HZ series, Rubycon ZLH,ZLJ are good replacements.
    Badcaps store has them (check the main page). If you don't want to order from this site for some reason, digikey.com and newark.com should have them.
    Keep in mind you should all capacitors in that area near the two swollen capacitors even if they don't look bad. Some just go visually bad sooner than others but they may all be bad inside.
    • anteck7
      • May 2012
      • 5
      Specs for the rls caps are
      8x12
      Impediance: 0.072
      Ripple 760
      Cosndering ordering these zljs from digikey. Ive been looking though the store here for the Nichicon but they dont have the specs listed for the capacitors....Or even a link to the datasheet..
      what im currently considering:
      http://search.digikey.com/us/en/prod...460-ND/3134416
      • mariushm
        • May 2011
        • 3799
        Yeah, those ZLJ will work but digikey doesn't have any in stock.
        here's what it will work (some of the below may be rated for 10v, that's perfectly fine, going up in voltage is ok)
        http://search.digikey.com/us/en/prod...PD9-ND/2428117
        http://search.digikey.com/us/en/prod...2354-ND/613715
        http://search.digikey.com/us/en/prod...MPD-ND/2428129
        http://search.digikey.com/us/en/prod...1647-ND/756163
        • anteck7
          • May 2012
          • 5
          Which ones on the badcaps store would you reccommend.
          The impeidance of those 10v caps seems to be different...will that matter?
          • mariushm
            • May 2011
            • 3799
            Impedance should be equal or lower.
            Lower is better but you shouldn't go the extreme way.. I mean sometimes it's not good to go for example for polymer capacitors that have 0.009 ohm impedance when your old capacitors were 0.072 ohm
            The ones I recommended have an impedance between 0.018 - 0.03 which is half the old capacitors' impedance, so it's not very low to be potentially bad for the board.
            From the Badcaps store, you should go with the Nichicon HM or HN 1000uF 6.3v/10v from this page: https://www.badcaps.net/pages.php?vid=23
            I wouldn't go for HZ, it's a bit too low impedance.
            • anteck7
              • May 2012
              • 5
              Am I the only one who cannot access this file.
              https://cdn.badcaps-static.com/pdfs/...43c4079d93.pdf
              • mariushm
                • May 2011
                • 3799
                No, their site is down at the moment to me as well.
                Here's all the datasheets : ftp://helpedia.com/pub/temp/datashee...tors/Nichicon/
                e-hm.pdf and e-hn.pdf are the HM/HN datasheets.
                • mockingbird
                  • Dec 2008
                  • 5484
                  Can you be more specific with the model? I'm looking at the Biostar TA790GXA2:
                  I see 3 Chemicon KZGs near the ATX connector that should be replaced. I see 12 of what I assume to be OST caps throughout the board that I would replace.
                  • anteck7
                    • May 2012
                    • 5
                    If you look at the board (sorry im on a chromebook, no photo editing software to speak of)
                    the 2 caps that are bulging are between the northbridge heatsink and the top stick of memory. I plan to start out replacing those 2, as those are the only ones with apparent damage.
                    The cap between the North Bridge and Top PCI express is also getting replaced. (3 total all located in the same area)
                    I'm presuming these are dying due to being located in a high heat area. I also presume they regulate and provide power to the North Bridge (which could account for the weird behavior I'm getting)
                    My friend who has the real nice solder station is out of the country right now, so in the long term, I may replace more (I ordered 10 total, I guess i should have ordered more). If I can replace those 3 and end up with a stable system, ill continue with replacement.
                    That being said, if I can change my order here, I may just order the whole set at this point. Will those HM caps work okay for the OST RLX 6.3v 1000uf?
                    • G-Laser
                      • Oct 2014
                      • 10
                      So, I have that exact MB and popped a cap. I also noticed a bunch of bulging ones so I thought I'd go and replace several of them. I don't have an ESR meter, yet, but have been looking for some schematics to build one just to make sure they're all good but from what I read, the brands on this board aren't exactly quality and the price of a cap is nothing.
                      So, would it be over-kill to replace the caps with Aluminum Organic Polymer? Seems that I could match the specs (or at least what specs I can find of the OST and RLT brands on this board). Any concerns or comments about doing that?
                      • omon
                        Please help find a replacement for Rubycon A0817 6.3V 1000uF 105C MBZ
                        by omon
                        I was hoping to get some help in identifying a replacement capacitor for a PET Rubycon A0817 6.3V 1000uF rated for 105C temp, MBZ series.
                        This is to replace one bad capacitor on a DELL 530 motherboard DG33M03 (manufactured by Foxconn, DELL part # FM586).
                        I'm attaching the pictures of the bad cap.
                        Thank you so much!...
                        04-28-2021, 05:43 AM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
                      • the_rem
                        Unknown transformer : how to find a good replacement part ?
                        by the_rem
                        Hello guys,
                        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                        04-23-2025, 01:48 AM
                      • ezenia
                        PS4 controller left stick potentiometer replacement issue
                        by ezenia
                        Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                        So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                        I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                        09-30-2023, 02:19 PM
                      • boosti45
                        Macbook pro logic board replacement parts quesion
                        by boosti45
                        i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                        08-21-2024, 05:23 AM
