Replacing LCD CapXon Caps
  • biatche
    • Apr 2012
    • 27
    • Malaysia
    Re: Replacing LCD CapXon Caps
    What do you call these white ?insulation? paste http://www.anandtech.com/show/2433/6
    I should get some.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5095
      • New Zealand
      That's just glue. It's used during assembly so things don't fall off. You don't actually need it.
      Incidentally, some kinds of glue can turn conductive over time and cause problems. So that's another good reason to stay away from it! (and also why some things fail)
      -David VanHorn
      • frannyjunk
        Vizio M60-C3 Replacing 1000uF 16V with 1000uF 35V capacitors?
        by frannyjunk
        Hi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
        Any thoughts if OK to use these higher voltage capacitors?
        11-04-2021, 05:59 PM
      • Y. Signal
        Recapping Mean Well MWP-606
        by Y. Signal
        Hello, I have this arcade power supply that I'd like to recap for maximum reliability and lifetime since I have found some Capxon and Jamicon capacitors:
        • Capxon GL 10x25 1000uf 16V Ripple: 1180 Impedance: 0.05ohm // Chemi-con KY 1000uf 16V Ripple: 1400 Impedance: 0.046ohm
        • Capxon GL 10x12.5 470uf 16V Ripple: 722 Impedance: 0.095ohm
        • Capxon GS 10x15 22uf 50V 85ÂșC Ripple: 100
        • Capxon KM 47uf 50V Ripple: 125
        • Jamicon TK 1uf 50V Ripple: 12
        • Jamicon TK 4.7uf 50V Ripple: 36
        I have another PSU (same model) that uses Chemi-con KY instead of Capxon GL, and since Panasonic FC are very...
        03-03-2019, 07:44 AM
      • competition
        Replacing capacitors in Evga PSU
        by competition
        I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
        11-14-2025, 11:12 AM
      • Alfieh
        NAD C320BEE repair possibly bad capacitors
        by Alfieh
        hey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
        recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...
        11-19-2024, 04:55 PM
      • ajdrenter
        Picking caps for Antec SU-380
        by ajdrenter
        In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
        https://www.badcaps.net/forum/showthread.php?t=14159
        It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
        05-13-2023, 10:40 AM
