I have just recently recapped a Jetway V266B with bulging GSC caps which has been showing symptoms of badcaps. Prior to this, I have never held a soldering iron before. I replaced all the bulging ones with Sanyo's having the same value, 1500uf 6.3v with my questionable soldering skills. When I fired up the board, I get a blank screen but the cpu & vidcard's fans spins. I have tried reseating the mems,cpu & vidcards. I have also tried resetting the bios & remove its batteries but no luck.
My guess is it's my amatuer soldering skills. Is there anyway to test the capacitors if I did it properly? What tools do I use? Help pls! I new at this...
