Help a noob
  • ngorge
    • May 2006
    • 5
    Help a noob
    I have just recently recapped a Jetway V266B with bulging GSC caps which has been showing symptoms of badcaps. Prior to this, I have never held a soldering iron before. I replaced all the bulging ones with Sanyo's having the same value, 1500uf 6.3v with my questionable soldering skills. When I fired up the board, I get a blank screen but the cpu & vidcard's fans spins. I have tried reseating the mems,cpu & vidcards. I have also tried resetting the bios & remove its batteries but no luck.
    My guess is it's my amatuer soldering skills. Is there anyway to test the capacitors if I did it properly? What tools do I use? Help pls! I new at this...
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Help a noob
    its quite easy to solder the capacitors in by closing the holes with solder, as long as they look closed and the solder is nice and shiny i doubt there would be a problem.
    one problem could be long heating, examine the traces around the holes, if you were heating for a loooong time then maybe a trace is lifted and you will see it obviously broken / missing a piece.
    i am assuming the board POSTed before the recapping
    after checking the traces, check also again for something you forgot. are you using the same components known to be working on that board? do you have onboard vga? etc
    • ngorge
      • May 2006
      • 5
      Re: Help a noob
      The board does POST prior to capping & I am using all the same components.
      Traces... are these the shiny rings around the holes? By saying "broken", does it mean that it's no longer a full ring? And how long is "a loooong time" in heating the traces?
      In this similar thread https://www.badcaps.net/forum/showthread.php?t=709, someone replied "turn it over while connected to psu.
      power on and test with v.o.m on low dc v range."
      Is this how to test the caps? can you explain that to a no-electronics background person?
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: Help a noob
        sorry my post was worded badly.
        the vias or lead ports are the rings around the holes
        the traces are the zillions of small lines snaking all over the board. look at the ones near the vias and see if one is broken.
        in that thread the board was not posting before the recap so kc8 wanted to know what was the voltage the cpu was getting in case the board had vrm damage. (this can happen when the caps fail and the board doesnt post again)
        you can do that to see if there is power loss to some part of your board if you like:
        so you would need a multimeter and you set it to measure dc volts on a low setting. for instance mine i set at 20. and then you power up the board, flip it over and then put one lead on one of a cap's leads and one on the other. so you measure the volts across the caps.
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • Azurain
          Elitebook 840 G5 Bios Chip Soldering Question
          by Azurain
          I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
          Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
          04-14-2023, 06:58 PM
        • Fam787
          HELP! A1398 Dead,
          by Fam787
          I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
          Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
          12-27-2024, 05:19 PM
        • Peter_1402
          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
          by Peter_1402
          Hi Everyone,
          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
          1. Soldering iron works great
          2. There is a burnt mark on the hot air gun handle.
          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
          Reed switch tested ok with a magnet.
          From the above test, I can conclude...
          07-12-2025, 11:50 AM
        • chth96
          What soldering station should I purchase for 900M-TJ-I tip?
          by chth96
          hello.
          A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
          https://ko.aliexpress.com/item/4001275635593.html
          Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
          Any reply would be appreciated.
          11-24-2023, 05:08 PM
