Have an (older) GeForce 6200 card with about 10 of these on it, as well as three caps, look to be polymers. (red print, marked (F with a line on top and under it) 833 821 2.5V). Sometimes this card starts going weird to the point that a reboot is necessary. Any chance that I'm dealing with bad caps here? I'm not sure on the three small ones.
KZG on GeForce 6200 PCI card
Re: KZG on GeForce 6200 PCI card
The ones marked with F are Fujitsu, they should be fine.
For the rest, how about you post a picture of the card?
But generally, the KZG capacitors are bad series, wouldn't hurt replacing them - it's just a question if it's worth doing it - sometimes cards are cheaper on ebay compared to the price of replacement caps. -
KZG should always be considered bad.
You aren't going to know if you have some other problem too unless they are replaced.
KZG specs are equivalent to Rubycon MBZ, Sanyo[Suncon] WG, Nichicon HM,,,,,
.Mann-Made Global Warming.
- Dr Seuss
by erdoshey guys,
I have an old homebuild PC with MSI K8N Neo Platinum 754 NVIDIA nForce3 250Gb ATX AMD Motherboard and Evga geforce 6600gt agp Card.
whenever I booted into windows7, an onscreen message pops out - warning that nvidia card is not receiving enough power and is at reduced performance level. When I opened the case, the GPU fan on the nvidia card is not spinning. after a while, the card becomes extremely hot when touched. I have a new Cosair RMS 750Watts PSU for the pc - replaced an old TruePower 380Watt ATX12V Power Supply, and the extra molex connector on the... -
NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...-
Channel: Schematics and Boardviews
NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...-
by sam_sam_samThis is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it... -
NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...-
10-01-2024, 01:54 PM -
- Loading...
