Please Help ID This Cap
  • Luckyboy1
    • Apr 2006
    http://img.photobucket.com/albums/v3...052_edited.jpg
    because I need to know type of cap and values of same.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Please Help ID This Cap
    they are oscon svp 1200uf 4v.
    • proxneo
      Recapping Sony ICF-SW55 - verifying cap values
      by proxneo
      Dear reader
      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
      At the moment, I have selected replacements based on the following list of values:
      3 x 470uF 10VDC
      3 x 4.7uF 35VDC
      4 x 47uF 50VDC
      8 x 22uF 6.3 VDC
      1 x 220uF 6.3VDC
      5 x 100uF 6.3VDC
      Which...
      06-21-2023, 12:38 AM
    • rashidjafar
      Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
      by rashidjafar
      I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
      Values for :-
      PC43 : Capacitor [3x1.5mm]
      PL7 : Inductor [2x1mm]
      PC39 : Capacitor [1x0.5mm]
      Any ideas would be appreciated.
      I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
      08-07-2025, 05:10 PM
    • Kobok
      Different (lower) resistor values on PCB?
      by Kobok
      Dear Alls,
      For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
      09-19-2022, 07:30 AM
    • skdsp
      Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
      by skdsp
      I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
      Attached is the photo.
      Thank you!
      09-27-2025, 09:05 PM
    • DeXXter
      HP VICTUS 16-d0500la Some Values
      by DeXXter
      Here some measurements on HP Victus 16-d0500la, it might help someone, the values are on diode mode->mV and some lower ones on Resistance->Ω.
      This specific laptop has an Intel i5 11400h + RTX 3050TI, the values are from a working laptop....
      03-13-2025, 03:16 AM
