RP=can I replace 1500ul 10v caps with 1800ul 10v ??
  • max2004
    • Dec 2011
    • 7
    Just placed my order this date(04dec2011)
    I ordered 1800ul 10v instead of the 1500ul 10v.
    It's a IbeeM 13R8926 MB that is prone to bulgers
    I bought some caps from a local guy and even those bulged
    within a year.
    Any advice appreciated.
    Thanks,
    sigpic
    Official Bulger De+Re-Capitator
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: RP=can I replace 1500ul 10v caps with 1800ul 10v ??
    That should not be a problem.
    Low ESR caps are +/-20% for uF anyway and 1800 is 1500+20%.
    - And, uF goes down as caps age.
    If your caps keep bulging either you are using the wrong kind of caps [meaning not low enough ESR] or the PSU is bad or you have heat/cooling problems.
    [Or a combination of those.]
    Mann-Made Global Warming.
    - Dr Seuss
    • max2004
      • Dec 2011
      • 7
      That's a relief . . .
      I'm putting this MB in vertical case.
      I've always used oversized CPU heatsinks and industrial
      type cooling fans.
      The old desktop case PSU had a few bulgers.
      But I didn't put 2+2 together till you mentioned it!!
      Thanks a lot.
      sigpic
        by momaka
        03-12-2025, 03:42 PM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • edith
        Caps and how to find one to replace
        by edith
        Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
        Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
        Thank you!
        06-11-2023, 05:00 PM
      • madscientist750
        Replacing electrolytic caps by solid caps on old motherboards
        by madscientist750
        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
        10-19-2025, 06:10 AM
      • Mattz_GT
        Which caps to replace: ECS P4M800Pro-M V1.0A
        by Mattz_GT
        It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
        I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
        Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
        Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
        PS. Additional diagnostic,...
        01-22-2025, 12:12 PM
