I think this capacitor is bad but can't tell
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    So in my Linux Router, I have an FSP power supply. This one specifically: http://www.newegg.com/Product/Produc...82E16817104045
    It hasn't been used that much. It was in a HTPC for about 3 months and in my Linux router running for only 3 weeks straight now. The primary caps are CapXon, and from what I can see, there are some Teapo and CapXon on the secondary side. I looked inside the PSU, from the back grille while it was running and it looks like one of the main caps is bulging a little. Since it is somewhat hard to see, I can't tell if it's bad or just the angle I'm looking at. I'm lazy and I don't want to actually shut it down and take it out and open it since it's still under warranty and it's still powering the computer just fine. So I am wondering, even being CapXon, what are the chances that one has gone bad on the PRIMARY side just after a few months of use??? The only Primary caps I've seen die are Fuhjyyu's
    Just in case, all it's powering is a Pentium 4 2.8 no HT, 2 RAM sticks, 1 hard drive, no graphics card, and 2 case fans. In other words, nothing.
  • yyonline
    • Jul 2009
    • 692
    Re: I think this capacitor is bad but can't tell
    Primaries bloating after a few months is unlikely, even if they are Capxon. Are you seeing the top of the capacitor bloating, or is the top of the capacitor covered with a plastic disc? The plastic discs will bloat from heat and the air trapped under the disc expanding. A bloated plastic disc does not mean the capacitor under it is bad. FSP isn't the best quality, but they're not "gutless wonders" either. FSPs don't usually have "warranty seals," so you can open them up to check the condition or clean them without voiding the warranty.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Thanks for the reply! Yeah the top of the capacitors have plastic discs on them.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        It's called insulation. [hehehehehe]
        They sometimes do that on big caps to reduce the risk of shorting something.
        Mann-Made Global Warming.
        - Dr Seuss
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Okay cool, that makes me feel better. Thanks!
          • MORETTIGIAN
            by MORETTIGIAN
            Title:
            Description:
            Procedure performed:
            - Removed backplate
            - Reapplied thermal compound
            - Reassembled card
            09-18-2025, 12:14 PM
            KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
            by momaka
            For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
            http://www.rmac.kingwin.com/products.../abt_650MM.asp
            I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
            What mostly drew me into buying it is its 2x PCI-E power connectors...
            03-29-2022, 11:34 PM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • chth96
            by chth96
            12-22-2023, 04:34 AM
          • chth96
            by chth96
            06-02-2024, 07:31 PM
