The title is the question. What are the ratings on all the caps on the power board of a Samsung 2333SW? I want to have all the replacements in my possession before I open my monitor. Thank you.
Cap specs (all) for Samsung 2333SW power board
Tags: None
Re: Cap specs (all) for Samsung 2333SW power board
There is no way to tell. Even if somebody else found the cap ratings for a 2333SW, there are tons of small variations in board revision, etc...
You've got to open it up and read the capacitors, there is no other way. -
That's true.
It's not uncommon for the same make/model of screen to use several different power boards over it's production run.
I have a Viewsonic I need to open up and I already know this model used at least two different power boards after researching problems specific to the model.
.Last edited by PCBONEZ; 11-07-2011, 11:41 PM.Mann-Made Global Warming.
- Dr Seuss
I can only suggest searching ebay for "samsung model ### power board" :
http://www.ebay.com/sch/i.html?_from...All-Categories
Look at the pictures, that MAY give you an idea about the values of capacitors but as it was already said, you have no guarantee your board will have the same design or even the same capacitor brand (some are Chinese clones of the original power boards).
I guess you're living somewhere remote or where there aren't retail stores so you're hoping to order parts before you open up the monitor or something like that... well you may go this route but it's a gamble.Comment
Assuming...7 Photos -
by CooperrI picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
• Have obtained Samsung schematic & service documents - Can upload if helpful.
• Have read ALL applicable threads
• C1818 and CP820 replaced as low hanging fruit
• CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
• VCC pin (18) of PFC... -
by NicktronicHey everyone,
This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
Anybody... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos - Loading...
