I got another Intel board that has a problem. I noticed that if the onboard VGA is set to 32MB (wich is the maximum number) the board would fail to boot and making a 2 short followed by 6 even shorter beep. At first I thought that it's because the 2 broken caps (one under the PCIe slot and one above the PCIe slot right below the North Bridge). So I replace the two caps and it would boot once. But when I try too restart the board, it failed to boot again with the same symptoms (the beep). So I try to boot the board while giving a pressure to the North Bridge and walla... It's working... So I think the Bridge needs to be heated again, but I don't have a hot air station. And when I try to look for other clue about what causing the problem, I found that the choke next to the cap I recently replaced is very hot! and the 2 caps that I just replaced and a Mosfet near it are becoming very hot too. So I think that the problem is caused by a failing choke. So, what do you think guys? Is it the choke? How can I repair the choke?
How to repair mainboard choke?
by pkslowkSr. Motherboard Debug Error Code Solution
1 Intel 845 E9 Bios Related Problem
2 Intel 845 D4 CPU Socket Related problem
3 Intel 845 37 Bios Related Problem
4 Intel 845 7C Bios Related Problem
5 Intel 945GCPE 34 Bios Related Problem
6 Gigabyte 845 2 Ram Related Problem
7 IBM Server A6 A7 Ram Mismatch Problem
8 Asus 845 29 CPU Related Problem
9 Lenovo I946 97 C-Mos Jumper related
10 Gigabyte 845 A0 CPU Related Problem
11 Asrock G31M-VS D7 Bios Related Problem
12 Compaq 845 BD-70G B0 CPU Socket Related problem... -
by privato89Hello everyone,
I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
Let's begin:
Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the... -
by Roman555Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
- Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
- USB stick with MS-DOS can be loaded via F8 boot menu;
- Other OSes won't load - hangs or goes reboot;
- Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
- An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
- Cleared CMOS many times;
- Flashed different versions of BIOS in a CH341 programmer;
- Updated
by Luke AndersHi everyone,
A few details about the laptop itself:
Name: Lenovo Legion 5
Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
BIOS Version: GKCN60WW
EC Version: GKEC65WW
Serial Number: PF39AQ7Z
Board Model: NM-D562 Rev 3.0
RAM: 16GB Installed, DDR4 (brand new)
NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
I bought this laptop recently from eBay as a faulty device.... -
by hinisaI'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...-
Channel: Troubleshooting & Designing Networks
- Loading...
