Here are all the caps I see on this motherboard (haven't used it yet, it's still new in a box, I will probably be using it soon after getting $$ to build it up more:
newegg.com order date was 6/6/2005, so that gives you a idea of the age.
4 "KZG" 16V 1500 UF caps Other Numbers: (M)105 C (Temp I guess) 4 (7) OS
10 "KZG" (unsure, the tiny logo on it looks like the logo on the 16V ones above) 560 2.5V caps. Other numbers on them: A 496
22 "KZG" 6.3V 1000 UF Caps Other Numbers on them : (M)105 C (Temp I guess) 4 (k) 8R
14 "Nichicon" 16V 100UF Caps Other Numbers On Them: 105 C (Temp I guess) A0443 VZ(M)
9 "KMG" 6.3V 470UF Caps Other Numbers On Them: (M)105 C (Temp I guess) 4(7) OD
59 Total Caps on this board.
Are these good? bad? I've never used the motherboard, it's still new in the box. I hope this helps add potential bad or good caps to the database and help more people avoid the plague of bad ones or provide good ones
Also, what is interesting with these is what the box for the motherboard claims, seen below:
Here are the rest of the photos I took. when I am not as tired and have fresh batteries for my camera I will take more/better ones if needed.
edit: full unresized photos of the above images so more detail is shown:
Unresized Photos
Unresized Photos
