Arcon caps????????
  • drtch1
    • Mar 2006
    Arcon caps????????
    I had bought some Arcon caps from eBay since there out at Digikey. Are the good? I see Arcon?? on bad caps forum list. Who makes them? I had some Elite brand caps go bad (poped tops) in a monitor that are rated at 1000uf 16volts. I am replacing them with a 1000uf at 25v. What do you think?
  • Rainbow
    • Aug 2005
    • 1375
    Re: Arcon caps????????
    1000uF/25V is OK but better use some higher quality caps.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      arcon are crap.i am looking at a pallet of dell psu's full of burst arcons.
      i have a half of a 5 gallon pickle bucket i pulled today.if my help hasnt dumped them into the dumpster.
      • drtch1
        • Mar 2006
        Thanks- I guess I won't use them.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          you can get panasonic fm from digikey they are good specs.
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
