Does replacing bad caps give much of a performance boost?
Does replacing bad cap give much of a performance boost?
My Computer.
AMD APU A4-3300 2.5ghz 1mb cache
Motherboard GigaByte GA-A75M-S2V
Kingston HyperX Blue DDR3 8GB (2x4GB)
SB Audigy 2 ZS [B800] Sound Card
500GB WD Caviar® Blue™
1 Terabyte WD Caviar® Black™
2 Terabyte WD Caviar® Black™Tags: None -
My Computer.
2 Terabyte WD Caviar® Black™ -
Re: Does replacing bad cap give much of a performance boost?
No, they won't give any performance boost. They just give better quality power to components which makes you system more stable and may give you better overclocking if you install capacitors of higher quality than the old ones.Comment
Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
ok thanks and those pictures are of my first 2 motherboard recaps.
im going to go pick up 5 more caps for the first board one of the old caps went if i were to replace the rest that would be 21 more caps to replace so i am just going to do the ones cloaser to the cpu and hope for the best for now at least.My Computer.
2 Terabyte WD Caviar® Black™Comment
That's a P4 board. Those are VRM capacitors. Likely Nichicon HM. Your replacements are Chemicon KMG, and are inadequate for use as VRM capacitors.
Let's take a look at specifications.
Nichicon HM 6.3V 3300uF has the following specifications:
ESR: 0.012 ohms
Ripple limit: 2800 mA @ 100kHz
KMG has the following specifications:
ESR: 0.038 ohms
Ripple limit: 907 mA @ 100kHz (840 mA at 120kHz)
When selecting a replacement, you generally want the same or less ESR, the same or more ripple. The KMG handles less than a third of the ripple that HM can handle, and has over 3 times the ESR.
Good replacements for HM include newer HM (there was a manufacturing defect with older batches), Rubycon MBZ/MCZ (discontinued), Sanyo/Suncon WG, Panasonic FL/FJ.
I would also replace all of the HM capacitors, not just the failed ones. Just because they haven't visibly failed doesn't mean they aren't on their way.Comment
ESR: 0.012 ohms
ESR: 0.038 ohms
I would also replace all of the HM capacitors, not just the failed ones. Just because they haven't visibly failed doesn't mean they aren't on their way.My Computer.
oh and about those caps i put on there i had ordered rubycon caps but the caps that are on there is what they gave me i wasnt happy about it.My Computer.
Twice, when I've needed to Recap a mobo, I've written to "BadCaps.net" and requested the right caps for the job. I trust that I am always sent the proper caps for the job.
So far, so good. None of my replaced caps has ever failed (yet).
Maybe it's due to the new caps I just put in my own computer (with MSI mobo) or the fact that I gave the entire inside of my computer a very GOOD cleaning, but my CPU is running cooler, the fan is running quieter and the whole system just seems to have perked up. I did clean my CPU heatsink and fan and I installed new thermal compound to the CPU chip. That had not been done since I built this computer, several years ago now.
The best part is that I don't get BSOD's or crashes any more.
Now if I lay my Digital Temperature gauge, (my index finger) on top of my CPU heatsink, I detect almost no heat at all.
There is NO component inside any PC, that should run too hot to touch. It something makes you say "Ouch!!!" then it's too hot.
I could go on and on about how I eliminate heat from my PC components, but this is not the forum for that.
Cheers Mates!
The DoctorExperience is truly the best teacher.
Backup! Backup! Backup! Ghost Rocks!Comment
Cheers Mates!
The Doctor
A cold one -can- mean the heatsink isn't removing heat from the chip.
.Mann-Made Global Warming.
- Dr Seuss
Correct.
Cold heatsinks means either mean either it's incorrectly mounted (so cpu heat isn't transferred to the fins) or the heatsink+fan is oversized for the cpu.
When I'm not overclocking, I actually prefer to keep my computer more silent by lowering the rpm of the fans.
From the cpu's point of view, it makes no difference if it runs at 30-35c (85-95F) or 50c - most modern cpus throttle themselves down if they reach about 60-62C or power off the system. I'd rather be able to sleep at night with the computer running than keep the cpu pointlessly cold.
The only thing that people have to pay attention to when they make such decisions is protection of the surrounding vrm circuitry and capacitors. Some motherboards assume the air pushed down by the stock cpu fans will move over the vrm and keep it reasonably cool. With modern heatsinks with lots of heatpipes and fans blowing air horizontally through the fins, the vrm may overheat when overclocking.
just to show what i mean, i have this exact cooler, Zerotherm FZ120. Without airflow from the other fans in the case and on a cheaper motherboard without heatpipes on it, the vrm may overheat with such cooler.
PS. I've had about 5 different systems in my life - the only one I was really concerned about heat was one with an Asus P5ND2-SLI motherboard:
Without overclocking, when playing games the red heatsink would reach temperatures close to 70c... by design, they assumed fans would blow air down on the board and automatically cool down that heatsink as well. Even online reviews mentioned this at the time that it's a bad idea to run it without fan.Last edited by mariushm; 09-14-2011, 11:39 AM.Comment
I'm no novice to this computer game.
I built my first PC in ~1983 and I've been building them professionally ever since.
I lost count of how many systems I've built and run over the years, since that first system.
I use nothing but AMD processors and usually the OEM heatsink and fan.
Experience tells me that the OEM cooler is more than sufficient to keep the CPU chip running nice and cool, as long as the heatsink and fan are kept clean. (AMD CPU's run cooler than Intel CPU's anyway)
A cool heatsink indicates that the cooling fan is doing its job, not that the heat transfer between the cpu and heatsink is failing. As a professional, I would know the difference.
Right now, after the PC has been on for about six hours, 'Speedfan" tells me that my CPU core temp is 47°C.
Cheers Mates!
The DoctorLast edited by ThePCDoctor; 09-14-2011, 12:05 PM.Experience is truly the best teacher.
SpeedFan isn't accurate on modern hardware. It worked in the P4/AXP days, but no longer. Try CoreTemp. And also, idle temps are irrelevant. Load temps are what counts... is it more likely for your system to crash doing nothing, or is it more likely to crash when you're running heavy software?Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Cheers Mates!
The Doctor
I'm a Retired Electronics Tech. My specialty was electronic control systems for Nuclear Power plants.
I was also a Certified Nuclear Reactor Operator and I retired as a QA Inspector.
Did PC's on the side since '95 and since retiring [10 years ago] I've been doing actual -component- level repair on motherboards.
I got into it because it's easy compared to what I used to do.
You come off like a typical 'board swapper' tech. That's fine but that's not what we do here.
We actually fix the boards. That's our 'thing'.
If you actually think a A cool heatsink is a -definite- indication that the cooling fan is doing its job then we have teenagers here you should be listening to because they know more at component level than you do.
.Last edited by PCBONEZ; 09-14-2011, 12:38 PM.Mann-Made Global Warming.
- Dr Seuss
Also, a dead giveaway of poor thermal transfer is high variation between idle and load temps and fast temperature changes, if the processor goes up or down 20 degrees suddenly then it's very likely that the thermal transfer is poor... I've actually had a chip where the thermal material inside the CPU itself, under the IHS was the cause.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Popcorn anyone?Mann-Made Global Warming.
- Dr Seuss
System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFPComment
Hahahaha
That was in the 70's...
- Dr Seuss
in a way it CAN be true. If you have a bad cap giving your CPU too much juice and causing it to run hotter...some motherboard are set to downthrottle if the CPU gets hot. so in SOME instances it can increase performance...by fixing a larger problemCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
This specification for the HP EliteBook 850 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Samsonite Base Boost boardview and 850 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 09:00 AM
This specification for the HP EliteBook 840 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Samsonite Base Boost boardview and 840 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 09:00 AM
This specification for the HP ProBook x360 440 G1 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 440 G1 + Samsonite Base Boost boardview and 440 G1 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...09-06-2024, 09:00 AM
This specification for the HP EliteBook 830 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G5 + Samsonite Base Boost boardview and 830 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 09:00 AM
This specification for the HP ProBook 650 G4 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G4 + Samsonite Base Boost boardview and 650 G4 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 09:00 AM
- Loading...
