Help, I need to identify capacitors
  • chele591
    • Aug 2011
    • 5
    Please help me identify these capacitors and if I can exchange them for something that can be found in the trade or equivalent ...!!!
    Hay (4) FZ83 1500 6.3V, (1) FZ78 1000 16V, (1) Red 7Y1b 331 16
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Help, I need to identify capacitors
    Sacon FZ series. - They are junk.
    Sometimes they come with black markings instead of blue.
    The Red one is a Fujitsu Polymer.
    Leave it alone, those don't go bad.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      https://www.badcaps.net/forum/showpo...88&postcount=2
      - Dr Seuss
      • chele591
        • Aug 2011
        • 5
        Ok thanks, I know if I work or traditional capacitors must be some special specification
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          They are low ESR caps.
          Just need same uF/volt caps:
          - With the same or less ESR.
          - The same or more Ripple.
          - That physically fit.
          - Dr Seuss
          • chele591
            • Aug 2011
            • 5
            I can install 1500UF 16V instead of 63V?
            I can only get these ..!
            • Rulycat
              • Apr 2010
              • 724
              • United Kingdom
              A higher voltage is fine as long as it meets the same or less ESR and has the same or more ripple, and of course, if it fits.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Only if the actual circuit voltage is 16v or less.
                That's not real likely if they were using 63v caps.
                - Dr Seuss
                • mariushm
                  • May 2011
                  • 3799
                  It's probably a typo, he probably meant 6.3v - that's the value in the picture.
                  So the answer would be 16v instead of 6.3v is fine, provided :
                  the ripple is >= than old one
                  the ESR is <= than old one
                  the diameter (or width) is small enough to fit in the space the old ones used.
                  hmm... i think this is my first post here... somewhat long time lurker but I'll probably bug you all with questions soon as I'll receive a Samsung monitor that needs repairs in a few days.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Just the same, answering yes without clearing that up might lead someone reading this later on to think replacing 63v caps with 16v caps is okay, which it isn't without checking that the actual voltage is less than 16v.
                    - Dr Seuss
                    • chele591
                      • Aug 2011
                      • 5
                      Oops Sorry is 6.3V, and if thank you very much for your help, my video card revived many but thank you very much, in the end install 1500UF 16V, and again thanks ...!!!
                      • dragon3x
                        After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                        by dragon3x
                        Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                        power on.
                        Here are some examples :
                        (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                        switching supply area).
                        (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                        than 6.3 V.)
                        1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                        I replaced capacitors with aluminum-polymer.
                        3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                        03-21-2025, 02:46 PM
                      • slybunda
                        AA and AAA battery charger capacitors?
                        by slybunda
                        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                        it has inside:
                        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                        2 x 470uf 16v LZ105c branded as G.Luxon
                        not heard of these brands are they any good?
                        iv attached photos of the charger and the board inside for an idea on the type of...
                        12-24-2023, 04:41 AM
                        by sam_sam_sam
                        After all of...
                        07-13-2024, 08:14 PM
                      • Cama
                        Solar Inverter - SMH-II - 2 missing capacitors
                        by Cama
                        I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                        My model is : EASUN SMH-II 7 KW
                        Mother Board : P/N 18947-002401250250
                        Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                        Thank you...
                        09-12-2025, 02:50 AM
                      • Ady2017
                        Are there any datasheets available for Elna RJG capacitors?
                        by Ady2017
                        I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                        05-25-2025, 02:19 PM
