Manufacturer Cap types interchangable. Possible Supplier?
  • JonMC
    • Aug 2011
    I have recently been assigned the task of sourcing caps for recapping motherboards. While investigating some faulty motherboards a few manufacturers names have come up, namely Rubycon, Nichicon and Panasonic. I have various models of motherboards for repair, and each motherboard varies a little at times in which manufacturer it seems to use. I understand they are all of the Low ESR type, is there a reason why one motherboard would have a Rubycon rather than a Panasonic of exactly the same value for instance?
    Can I simply use any brand as long as it is of the Low ESR type? This would make sourcing the various caps I need easier.
    Also, do you all know of a good source I could aquire these caps, I have spent sometime on google and it is proving to be a large task. I have found a lot of them but from a large selection of sources, with varying prices and varying small quantities which doesn't really suit for my needs. I would need a steady supply each month of these caps so ideally one source would be good with a reduced price for larger quantities. I cannot say for certain how many, but I will be repairing around 400 units a month so quite a reliable source would be needed.
    Many thanks for any assitance you may have to offer me on this matter.
  • digge
    • Apr 2006
    • 296
    Re: Manufacturer Cap types interchangable. Possible Supplier?
    Why the manufacturers pick a certain brand and model depends on lots of stuff. Of course the spec of the cap have some influence but price and availability among other parameters are involved as well.
    Generally speaking as long as you follow the ESR, ripple, volts and uF somewhat close you can pick just about any brand. Depends on what job the cap has in the circuit if you can go for better ESR or more uF and so on. My personal rule of thumb is "when in doubt, go as close as original you can but with a known good brand".
    Also generally you can always go up in voltage without problems if that's what you have around. Never go down in voltage unless you are 100% sure that they "overdid" it with a higher voltage cap.
    Beware however the size of the replacements when ordering, or you might not be able to fit them on the board you are working on.
    Out of time now, i end work now so time to go home, someone else might fill in more blanks
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      There is not just different brands.
      Each brand has different series which will have different ESR and Ripple ratings.
      ESR needs to be the same or less. [Ohms at 100kHz and 20°C]
      Ripple needs to be the same or more. [mA at 100kHz.]
      UF should ideally be the same. [If you MUST change due to availability then go up 20%.]
      The voltage rating is a limit so more is okay, but no benefit to it.
      https://www.badcaps.net/forum/showpo...1&postcount=17
      Mann-Made Global Warming.
      - Dr Seuss
      • JonMC
        • Aug 2011
        Thanks for the information, I will need to look closer at the ESR and Ripple values but things are a little clearer now, much appreciated.
        • ahmedtou
          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
          by ahmedtou
          help me please
          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
          I will share all the details with you, including the disc information.
          Code:
          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
          Current Profile: BD-R
          Disc Information:
          Status: Empty
          State of Last Session: Empty
          Erasable: No
          Free Sectors: 12,219,392
          Free Space: 25,025,314,816 bytes
          Free Time: 2715:27:17 (MM:SS:FF)
          Next
          08-27-2025, 08:49 AM
        • madscientist750
          Replacing electrolytic caps by solid caps on old motherboards
          by madscientist750
          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
          10-19-2025, 06:10 AM
        • qwerty99
          Xbox 1.6 Motherboards and Polymer Capacitors
          by qwerty99
          Hello!
          I need to change the capacitors on my three original Xboxes.
          Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
          The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
          The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
          I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
          06-26-2022, 12:53 AM
        • Foetuss
          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
          by Foetuss
          Hi all
          Hope this is in the correct place.
          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
          Could use some double checking to see if I'm not doing something stupid .
          Pictures of the boards are attached.
          What I will be replacing with what : (planned)
          Soltek Golden ::
          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
          01-18-2025, 11:44 AM
        • madscientist750
          Looking for capacitor lists for Motherboards, Video Cards, Home Appliances
          by madscientist750
          I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
          07-09-2024, 09:24 AM
