KZG or OST - Which are better?
  • lti
    • May 2011
    • 2557
    I am looking at buying a new computer, but it seems that most motherboards have either OST caps or KZGs. Some computers even have both. Is one brand/series better than the other or are they equally crappy?
  • mockingbird
    • Dec 2008
    • 5484
    Re: KZG or OST - Which are better?
    Hmmm.....
    KZG will last longer than OST, but beware, they fail without bulging. OST are more likely to bulge when they fail so at least you can tell when they need to be replaced. OST also fail without bulging.
    Which new motherboards have these caps? Must be some really low-end OEM from China.
    • lti
      • May 2011
      • 2557
      They are not low-end boards. Almost every prebuilt computer that I was able to look inside had these caps. I also saw them on MSI, Biostar, and Asrock boards. You have to look at some high-end boards to get away from the crappy caps.
      I want to know which caps would last longer.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        I'd say equally crappy.
        If I had to choose I'd go KZG because at least they stick to standard sizes I can find replacements for.
        Should be able to find boards with mostly polymers now days though.
        If buying a complete 'factory' system get a Dell with an Intel built board in a tower case.
        Least of the various evils.
        Mann-Made Global Warming.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          MSI, Biostar and Asrock ARE low end boards.
          If it's still using mostly lytics it is a low end or mid range system.
          Even most mid-range have polymer now, at least in the VRM.
          - Dr Seuss
          • lti
            • May 2011
            • 2557
            I thought he was talking about really low-end manufacturers like PCChips. A lot of prebuilt computers (junk like HP/Compaq) use ECS boards with Nvidia chipsets. It can't get much worse than that.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              MSI might be slightly above HSING Tech boards but Biostar isn't and Asrock certainly isn't because Asrock is built by HSING Tech for Asus.
              HSING Tech is the actual manufacturer of PcChips, ECS, and Asrock boards.
              - And the parent company behind PcChips, BTW.
              PcChips is just the distribution network for HSING Tech.
              Years ago I mistakenly had email exchange with the CEO of HSING Tech.
              I had asked customer support if it was possible to build a mobo with some configuration. It was intended to be a rhetorical question but I think that got lost in translation.
              My email got directed to the CEO who responded [paraphrasing]:
              "Sure, if you order 20,000 units".
              - Dr Seuss
              • lti
                • May 2011
                • 2557
                PCChips boards were always really crappy, but other brands of boards made by HSING Tech were slightly better. I was just using them as an example anyway.
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  brand new cheap MSI's are actually doing pretty good now a days. they still have some older offerings for 'super cheap' AM2+ board that they use pannys on vrm and kzg's for the rest
                  MSI is getting better and better about polymer caps. thier newer boards are using sanyo for lytics and all the rest polymer are resuling in some good talk about them. infact I just found one of thier amd boards (nvidia chipset though)
                  http://www.newegg.com/Product/Produc...82E16813130594
                  all solid and looks like higher quality build. I've been seeing this trend with MSI. seems they're leanring thier lessons
                  you're right about biostar and asrock (which is asus's cheap comapny)
                  • mockingbird
                    • Dec 2008
                    • 5484
                    All those nForce boards must be old stock... Anyone who buys them is out of their mind.
                    • TBoneit
                      • Jun 2010
                      • 70
                      I'll agree with that. I also put Foxconn in as second tier.
                      I just looked at a cheap Sandy Bridge board from ASUS P8H61-M what capacitors are on it all look like Polys to me.
                      • TheLaw
                        • Jan 2011
                        • 477
                        Why? They are dirt cheap...and not THAT bad.
                        • Rulycat
                          • Apr 2010
                          • 724
                          • United Kingdom
                          nForce chipsets had bumpgate where they would fail due to bad BGA's. You'd have to either reball them or get out the heat gun.
                          • TheLaw
                            • Jan 2011
                            • 477
                            Ohh...you mean the problems they had. Gotcha. Does it apply to all nForces? Probably explains why my POS HP laptop died. (Never buy HP).
                            • Rulycat
                              • Apr 2010
                              • 724
                              • United Kingdom
                              Pretty sure it does yes. Maybe except the 780i onwards.
                              • mockingbird
                                • Dec 2008
                                • 5484
                                Bumpgate and BGA reball were two different things.
                                Reballing won't fix a bumpgate chip.
                                The bumpgate chips die and they cannot be fixed, period. Anything after nForce 4 is affected.
                                • qwerty99
                                  Xbox 1.6 Motherboards and Polymer Capacitors
                                  by qwerty99
                                  Hello!
                                  I need to change the capacitors on my three original Xboxes.
                                  Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
                                  The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
                                  The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
                                  I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
                                  06-26-2022, 12:53 AM
                                • Foetuss
                                  Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                                  by Foetuss
                                  Hi all
                                  Hope this is in the correct place.
                                  I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                                  Could use some double checking to see if I'm not doing something stupid .
                                  Pictures of the boards are attached.
                                  What I will be replacing with what : (planned)
                                  Soltek Golden ::
                                  4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                                  6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                                  01-18-2025, 11:44 AM
                                • madscientist750
                                  Looking for capacitor lists for Motherboards, Video Cards, Home Appliances
                                  by madscientist750
                                  I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
                                  07-09-2024, 09:24 AM
                                • blues_spirit
                                  practical courses for troubleshooting pc motherboards
                                  by blues_spirit
                                  Hello from France,
                                  mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                  Do you think this is feasible for me? I...
                                  12-18-2022, 12:56 PM
                                • Deby
                                  List of compatible laptop motherboards
                                  by Deby
                                  This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                  And it's still ongoing.
                                  Every time I come across information that a board is compatible with another, I write it down.
                                  Anyone who wants to, can continue to expand the list.
                                  Packed in the rar, is an excel table that has additional information.
                                  Motherboards.rar...
                                  05-31-2024, 04:34 AM
