I have two motherboards that self-start when I turn on the power supply switch. I can of course turn off the machine by pushing the power switch on the front for 5 seconds. Using the same power supply on other boards shows that this is a board issue and not a PSU issue.
Both boards post fine, if a bit slowly, and run fine.
What causes the self-starting and what does it indicate?
