Re: Chemi-Con KY to replace OST RLS?
You're welcome & Congrats!
Replaced 60 caps between 4 boards and all are working perfectly -- thank you for your help pcbonez!!!
Yup.
Sometimes the sizes they choose to make don't make much sense.
Not even sure why they still make both 6.3v and 10v when a 10v will work for both.Leave a comment:
Went with the 10v KZE's.
I know they're compatible, but didn't think to search UP a voltage. I guess I was thinking that since the 6.3's were too big (10mm vs. 8mm), that a bigger voltage wouldn't be any smaller in size.Leave a comment:
See links above.Leave a comment:
No, I didn't check the datasheets. I NEVER do. I just assummed that RLS = HD = ZL = KZE = WX, since those are about the highest ESR series I usually see on motherboards.Leave a comment:
I'm probably leaning towards the KY's - it'd be around $65 for qty. 500 at Digikey for these, which seems decent, and also because the only 1000uf/6.3v KZE's that I see there are 10x12.5, unless I'm missing them.
I'd prefer purchase from Digikey if at all possible.Leave a comment:
http://search.digikey.com/scripts/Dk...me=565-1647-ND
http://search.digikey.com/scripts/Dk...me=565-1486-ND
http://search.digikey.com/scripts/Dk...me=493-1467-ND
Since you need many....
The 10v KZE would be my choice because it's an upgrade and only $0.255 each over 10 pieces.
.Last edited by PCBONEZ; 05-02-2011, 04:07 AM.Leave a comment:
Brush up on reading data sheets.
The 10 Volt 8mm 1000uF RLS [should be] 16mm or 20mm long.
Also ZL, KZE, KXM, WX, HD, and NRSG [in other words every series suggested] all have a 1000uF 10v 8x20mm.
If the height is a problem that's another story but it shouldn't be an issue in most cases.
That said, I falsely assumed c_hegge checked the RLS data sheet before posting.
The 8x16mm 1000uF 10v is only .090 ohms ESR and 818 mA for Ripple.
The 8x20mm 1000uF 10v is only .067 ohms ESR and 1023 mA for Ripple.
[If it's actually 12.5mm long as you said then it's a custom size and the specs will be worse in a smaller can.]
KY - 6.3v 8x15mm - .087 ohms ESR and 840 mA for Ripple
KY - 10v 8x20mm - .069 ohms ESR and 1050 mA for Ripple.
In this size anyway KY is about as close to an exact match as you can get.
The caps mentioned earlier would be a reasonable upgrade though.
.Leave a comment:
Motherboard from a Gateway E-2610D, ECS motherboard 945GT-GB V:1.1. Just a few are bad around the north/south bridge, but 14 of this same cap on board and will probably replace just the 14 of this particular cap. The rest all look fine and are other make - e.g. Ruby MBZ, etc.
I'm probably going to be doing a LOT of these boards in the near future.Leave a comment:
I did just notice that I originally said 10v, but these are indeed 1000uf/6.3v. :SLeave a comment:
It looks like those are all 10x12.5 or bigger? The original here is 8x12.5. Thoughts?Leave a comment:
Also Sanyo/Suncon WX, Illinois Capacitor KXM, and NIC Components NRSG.
The ideal replacment for RLS is Chemi-Con KZE, Rubycon ZL or Nichicon HD. KY has a higher ESR.
Btw, KZE is NOT affected by the problem that plagues KZG and KZJ.Leave a comment:
Still getting the hang of finding good replacements when the spec sheets don't include all specs.
Would a Chemi-Con KY series be a good replacement for an OST RLS series?
1,000uf 10v.
If not, does anyone have any better recommendations?Tags: None
by David StroeI am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
Main Board: 715G9500-M0C-B00-005K
T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
If someone could please provide any of these data sheets, it would be awesome....-
05-31-2025, 11:12 AM -
by RaulnnCan you clean the internal sheets of a tv? I have a 58-inch TV and I don't know if it's worth cleaning the sheets. I have seen that it has dirt on the sheets and the leds are blown. I don't know if they look good when you clean the sheets. Thanks in advance.
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
Channel: General Capacitor Questions & Issues
I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
What is your advice/opinion on whether or not on old(er)...-
by GRrHaGHi, I try to replace a VRM Alpha & Omega on a GIGABYTE 3080 TI Eagle,
marking BKU0 but i can't identify part number for buy it
Someone can help me ?
do you know here i can find Sch and brd file for this card ?... - Loading...
