Caps under the sink, would they benefit from contact?
  • robome
    I'm about replacing the VRM lyte caps on my board with polies.
    I'm quite limited in height since 8 of 10 caps are located under the CPU heat sink (LGA 775 board from MSI) which leaves just 12mm headroom. The old caps where 10mm in height but I couldn't get caps that small here around and thus have to go with 11.5mm.
    My question now is if the polies would benefit from actually touching the CPU cooler to get cooled. I don't know how warm they'll get by themselves.
    In the past (board is 2.5 years old) CPU mostly ran at 35°C and only went to about 45°C under load. On the other hand the CPU itself is no power beast (Pentium E2180, i.e. low end Core2Duo) and the Seasonic S-12 has a quite stable signal. Am I right in my assumption that this means not much to do for the caps and they won't heat up themselves?
    On the other hand I wonder why the lytes (OST, ESR of 0.029 mO according datasheet) have failed then in the first place (all bulged though not vented through the roof but blasted the rubber plug at the bottom) - besides the reason of being utter crap.
    The replace procedure itself is no biggie, already did that successfully some time ago on another board but that hadn't cap size constraints and I used normal caps.
    Thanks,
    Robert
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Caps under the sink, would they benefit from contact?
    IMHO: No, they would overheat.
    You are also blocking air from leaving the heat-sink.
    0.5mm sounds inadequate for top clearance too.
    [For that matter so does 2mm for lytics.]
    Were it me I would use a file or similar on the underside of the heat-sink [only in the area where the caps will be] and open the clearance up at least another 1mm if not 2.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      And here I thought this was going to be about caps in a garbage disposal...
      - Dr Seuss
      • robome
        Thanks for your answer. That little headroom surely is a design flaw of the board and I'd have gone the long road ordering some caps of 8mm height from the other side of the globe, wouldn't that system be my only system and thus needs repair fast (I'm typing this on my cellphone browser).
        So I'll try to give the caps as much space to the sink as possible - and do considder modifying the CPU heat spreader.
        Regarding garbage disposal. That play with words in the title only occured to me right after sending my first post.
        Thanks, Robert
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          where are you?
          order these
          https://www.badcaps.net/store/produc...products_id=79
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            the original caps might be slightly improved by contact with a garbage disposal!
            • TheLaw
              • Jan 2011
              • 477
              Same.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4973
                • New Zealand
                Yes I think those poor capacitors left all alone under the kitchen sink need some contact and affection
                -David VanHorn
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  so my cap stock being on old grocery store shelves out under the fluorescent lights should be happier?
                  and to answer the op's q no i would not put them in contact with the heatsink.if you do nothing but replace with the ones i linked above they will last well beyond the systems useful life.
                  • inuyasha.rules
                    • May 2011
                    • 43
                    Yes it will help if there's contact being made! Those Hobart 5hp garbage disposals sqeal and take forever to spin up with the start capacitor not conected.
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
